Ferrous and no-ferrous
  • #31
    for what? in original surf the delay pot is re-moved and uses like a pot for SAT tuning. the delay is fixed on 15us by multurn 50k R25, one time and on all life. this is Terry's mod.
    Ahhh .... thank you very much. I had no idea why.
    • #32
      The PWM function does not work in the code attached
      Ok thank you
      6666
      • #33
        Hi alber_gold
        Could you please tell me the full part number for the micro as there seems to be several max clock speeds
        • #34
          Hi alber_gold
          The full name is : PIC16F873 - 20 I/SP
          I think it serves any model.
          • #35
            Thanks I have ordered a PIC16F873 - 20 it will be here in about 10 days.
            • #36
              It's a good microcrontroller.
              It is cheap and has many resources.
              It is one of my favorites.
              You'll like it.
              __________
              PS: There is a book: PIC MICROCONTROLLERS Practical design applications II.
              From McGrawHill very good. I do not know if it will be in pdf format.
              • #37
                I agree with Joop
                If in a really junky location Induction balance is the way to go, However you will still be digging junk but not quite so much unless your like me because I tend to dig almost everything hence the bad back
                • #38
                  I agree with Joop
                  Joob right.
                  I'll ride one TGSL in a few weeks. Today I continue to study its performance.
                  I have not ridden before because I'm a bit poor ($ $ $ $ $ $ $).
                  When finished with the TGSL want TINKERER-model mount.
                  TINKERER seems like a great idea. It's a different concept.
                  And when finished with the TINKERER want to ride someone else.
                  Gradually I want to try several models.
                  Meanwhile I will continue with my tests. All my life I'll be doing tests.
                  Thanks Satdaveuk. My weary bones are grateful. :-)
                  Regards.
                  • #39
                    Pic has arrived.
                    • #40
                      Pic took the hex ok
                      • #41
                        Hello, I 'm happy for the PIC . :-)
                        If you are interested in further testing will be interesting this other code.
                        Change the scheme, but has some advantages.
                        - Did not use the NE555 .
                        - The PIC generates a signal with an initial period of 98 uS and a pulse width of 10 uS.
                        - With the " d " key pulse width is increased.
                        - With the "f " key pulse width decreases.
                        - The minimum pulse width is 1.8 uS.
                        We use the two bytes of ADC capture . ADRESL and ADRESH .
                        By PORTB only see ADRESL .
                        We debbug output console. I use Hyperterminal but there are many others.
                        It should be set as follows: 9600 8n1 Xon / Xoff
                        In RB 873 pin 7 is RX and RB pin , 6 is TX .
                        I use a USB to TTL converter like CP2102 USB port.
                        MAX232 , MAX233 , serial ports etc for COMxx also available.
                        We see this in the console : " xxx + ADC and ( zzz * 400ns ) uS " + CR
                        where :
                        - . Xxx = ADRESL in dec
                        - . Y = ADRESH in dec
                        - . Zzz = VALOR_A in dec
                        Like this :
                        To upload VALOR_A press "a" key
                        To download VALOR_A keypress " s "
                        The minimum tripping time is 600ns ADC and the maximum time is 102 uS.
                        Keep in mind that the time of each catch is 19.2 uS with a 20 Mhz crystal .
                        With this code I learned a lot . I hope you serve .
                        • #42
                          Hi alber_gold
                          Thanks for the information on new design.
                          Could you please tell us the new coil information Ltx/Lrx and what value is C1, thanks
                          6666
                          • #43
                            Hi alber_gold
                            6666
                            Hello, happy 2014.
                            I have tried many different coils and I can not pinpoint any particular.
                            You can try different coils and study their behavior.
                            You can also use a single coil.
                            56 ohm resistor. protects the transistor.
                            You can change to increase reach but not exceed the maximum voltage of a transistor CE.
                            I put C1 for options in the output signal. Different ways with different values.
                            Typically work without any capacitor.
                            • #44
                              Ordered another PIC16F873 - 20 to try new software
                              From Alberto in post #41 and ADC input, AN5 does not exist. Connect to AN4/RA5 --> pin 7
                              • #45
                                Alberto just want to check with you that the new hex needs 20 Mhz crystal ?
                                The new PIC took the new hex OK.
