Deepers Detector
  • Yes it's two colors led with CC (One common cathode, two anodes). CC connect to -9V
    And that's Guide
    • But maybe she iz then red(iron) or green( no iron)
      The pictures you put show white LED which is two colors. The pictures in x5 manual shows different LED
      • Because, a white LED can glow in two colors. And the instructions show which color is responsible for it.
        • That is what I said. You misunderstood. Look at the manual you posted, it doesn't show two color LED(white casing). The pictures on second post of this page does show deepers with two color LED.
          • Does anyone have a good reversed layout for the deepers x5?
            KT, where is your PCB to buy for deepers detector?
            • Hi to all .LDTVN if you can drawing the shime board of x5 please put it to us.
              • I can draw the board of Deepers x5 in SL6, but i need photos both sides of this board in good quality for this.
                  Really misunderstood, I translated incorrectly.
                  To Deepers x5 there is nothing but the scheme posted by the MFC
                  • Deepers 5 is very nice board, I saw pics only of top side of layout. No pics of reverse side.
                    So what is wrong with deepers 10dd? Why nobody make clone of original pcb board of deepers 10dd?
                    (I see printed on original pcb, deepers 10)
                    • Originally posted by LDTVN View Post
                      Who is interested in deepers x5 layout, I have Nice photos of both sides of pcb. It has big circle hole towards the front panel. Is this the one?. Then I can draw layout.
                      • It will be very good. Please post photo or pcb.
                        • Ok hi to all.
                          the led have 3 terminals, is a special led , lighting green on normal adjust and when the target is closer to the coil it change to red and cut the sound. The coil hipersensitive is 53x25 cm 2,5 r made of network computer cable.
                          I will post details soon.
                          take care.
                          • ok MFC
                              you can not draw layout just top lay covered by components partially. you do not see all pic. if you noticed
                              my top lay of deeprs 10dd was drawed and all covered traces was measured on connection. so i have clear pic. you not.
                              i say again - you can do only what in your hands keeping. aliens' photos does nothing.
                              • Hi to all . Is there enny new projet
