Serbian "Most Wanted"
  • bernte_one
    i think ist not totally wrong if you pickup ferrite
    while Tuning detector i set tune(or sens pot, or whatever you Named it) to middle positon
    then try if you can set ground pot to refuse ferrite and your bare hands too
    if detector sounds while sweeping your Hand over coil it will produce false Signal over real ground too.
    for good disc and ground Setup never put sens pot to Maximum (only in the range of 50-70%)
    if you are able to discrimate a 100g hammer and samewhile pickup a gold ring nearby all is ok
  • paun019
    nice well done
    Need help?
    Ferrite refuses but sees it from 30-40-50cm
    Where am I wrong?
  • bernte_one
    nice well done
  • Nandor
    Great job
  • Koala
    Nice build. Well done
  • markantony
    With thanks to Ivconic-https://youtu.be/t_8XnFMY470
  • bernte_one
    as i write before, manufacturer can handle this "wrong drill file"
    Problem is just the visualisation in program we use
    i dont make this pcb, for this design you Need a professionel pcb
    if you finish i would like to buy one pre-assembled in your ebay shop ;-)
    have not much time at Moment, my wife has many Tasks for me this year (some nice ideas for garden )
  • bandito
    Originally posted by bandito View Post
    I can see that.You have made an order for these files[ATTACH]39554[/ATTACH]
    The error is in the program I use
    Thanks bernte_one
    Did you make this board?
  • bandito
    [ATTACH]39551[/ATTACH]
    hope this helps
    I can see that.You have made an order for these filesClick image for larger version
Name:	error drill.jpg
  • bernte_one
    goodluck.zip
    hope this helps
  • bandito
    This file I generated.If you can share the production files(gerber).10x
  • bernte_one
    at another Project i had this too, but pcb manufacturer in China found nothing wrong- all pcb i got were correct
    you ca send files to pcbway the can proove files immediately, the tell you if something is wrong
    btw. which Version from this thread do you use? link the single post- i can check files for sure
  • bandito
    I have a problem.When generating gerber files,drill file Only one big point comes out.Can anyone share gerber filesClick image for larger version
  • ivconic
    Hello Ivica,
    where did you find Bibliothek which include Potentiometer Drawing
    or did you draw it by yourself?
    I can't recall from where i downloaded it.
    Most of the macros i am drawing by myself lately.
    But that one you are interested about ; i downloaded from somewhere long time ago.
    Looking at names of some macros; i think i took them from some Turkish forum.
    You don't need to bug yourself by searching; here it is the whole folder with lot of macros, potentiometer too:
  • bernte_one
    Hello Ivica,
