Serbian "Most Wanted"
  • emoxristov
    Thank you very much colleagues
  • ivconic
    Originally posted by Toros View Post
    BD140
    Yes.
  • Toros
    Originally posted by emoxristov View Post
    Tell me analogue BD136 Can I get it replaced
    BD140
  • emoxristov
  • ivconic
    My question was whether there are as pictured.BD136 -BD135 against each other
    I understand now!
    No, BD135 is turned wrong. Turn it for 180 degrees.
    Emiter is going down to speaker.
  • emoxristov
  • ivconic
    Was it a question? Not sure that i understand well!?
    BD135 and BD136, ECB pin assignment
  • emoxristov
    Ivconic , Really transistors are located at the bottom of the board.
  • emoxristov
    Thank simply LAY file you sent me below is seen how they put tranzistorite.Shte temata.Blagodarya read again for the help.
  • ivconic
    Thanks a lot can you upload the following scheme for BC547 will EBC. Antenna and data.
    Emoxristov you should read this thread from a start, already is explained well.
    BC547,BC327 pin assignment is always CBE.
    Coil ("antenna") can be Tx=1mH, Rx=15mH. Tx cap is ~ 470+47nF (parallel).
    Also Fisher coil can be used, 2.2-2.4mH for Tx and 9.6-11mH for Rx. Tx cap is ~220nF.
  • emoxristov
  • ivconic
    Ivconic can you send me a correct version of the board 555. I do it because I see my moshten.Tryabva metal detector for ferrous metals only if you can recommend me another option and I'm grateful.
    Yes.
    Here it is:
  • Davor
    Achieving Fe discrimination is easy - you just reverse the pins 5 and 6 of a comparator to set discrimination phase for Fe.
  • emoxristov
  • Davor
    Very true, but you did not try to extract C4 and see what happens with Tesoro after that
