Serbian "Most Wanted"
  • Gurdal asked me to draw him pcb for SMW with specific dimensions and shape.
    Here it is:
      Here it is:
      Master Ivica and Master Galaxy;
      Thank you very much separately.
      Yours truly
      • Hi master ivica;
        Everything is very beautiful;
        but he didn't sit on the panel
        Can you cut it according to the panel size?
        I'm sorry for being a burden
        https://www.dosya.tc/server32/o5mnl6...W_Box.rar.html
        • Originally posted by gurdal View Post
          Hi master ivica;
          I draw it according to your Sprint file template that you sent me.
          So...
          • thank you so much
            • You can change the button positions according to your own taste
                Drawing it again will be annoyance.
                I suggest to let it go and to try to draw SMD version instead.
                I can group components in the center of the template, so later you can cut redundant parts of the pcb.
                • Hi master ivica
                  Thank you for everything you spend your precious time.
                  Yours truly
                  Gurdal
                  • Check this template is it fit alright:
                    • Hello master ivica;
                      i guess now ok.
                      the previous drawing was very perfect;
                      box 3-5mm small
                      I attached a picture and a file.
                      I hope it works
                      Yours truly
                      https://s7.dosya.tc/server18/weh2l3/G_SMW_SMD.rar.html
                      • Hiya Gurdal,,,Any chance you could post your layout file please? Thanks, Regards, Marty.
                        • Master Ivica smw555 cd4066/LM358 Can you share the double tone kit or how do we do
                          • Originally posted by cnckecgo View Post
                            I don't know about that.
                            I used 4066 and LM358 for additional stage, for pinpointing mode.
                            Double tone is done different way, an optocoupler that vary threshold at 555, not good solution.
                            I never tried to add second tone to SMW. Other people maybe did, i don't know.
                            • Ok, Gurdal, here it is in SMD.
                              If you decide to make these at JLPCB or PCBWay, make one for me too.
                              And send me one pcb.
                              • Hi master ivica;
                                thank you so much.
                                you worked for us
                                I'll start with excitement.
