Serbian "Most Wanted"
  • 24vpp,8khz tx
    • Originally posted by Vladimir View Post
      Hi
      14V p-p voltage is too small for the detector.
      The frequency should be 5.4-5.7kHz
      I`ve found that increasing above 14v p-p doesn`t increase the depth in the ground and detector becomes more unstable.I`ll try to change the frequency.For resonate cap I put 47nf .Full resonance is at about 40nf. Is this correct for CC coil?When I put caps below 40nf I have problem in the ground -ferrite is rejected ,but I can`t detect 1 euro even at 20sm in the ground and smallest targets can`t detect at all.
      • With this tx is taken from a single detector with voltage of 10V in the TX going 24vpp the coil is very stable and without
        adjusting the oscillator.
        Coil in TX about 80n diameter of 0.40 to 20cm in diameter own body tx pay attention to 470nf which can increase to 1mf but asks that you fren. 8khz be around or slightly higher.
        Greetings
          Coil in TX about 80n diameter of 0.40 to 20cm in diameter own body tx pay attention to 470nf(1,5mf) which can increase to 1mf but asks that you fren. 8khz be around or slightly higher.
          GreetingsClick image for larger version
          • Can you post here lay file for the first pcb !
            • From 0.22 to 0.30 - OK My last coil has 42w 0.56 for Tx and 155w 0.22mm for Rx.I didn`t try it yet.
              42 tur 056 mm 155 tur 0,22mm rx
              Tx shield to minus,Rx shield to ground.
              tx folyo eksiye rx folyo grounda
              1 mH 15 MH
              İf I connect given coil BC327 heating and burning,how can I solve this problem?
              • http://www.4shared.com/file/npCrVZj4/srp_Most_Wanted.html
                • Hi gurdal.Very interesting. I see in the video is detected on the coin approximately 150mm max(if not a bit for this type of detector?).
                  • What must be the phase shift between Tx and Rx for DD and CC coils for SMW ?
                    • Hi gurdal.Trying to move a RX coil inside or outside until you get the best performance.
                      • 25 cents17cm-25 cents bronchus 16-18cm-silver ring 24-28cm
                        http://www.4shared.com/file/Inou6-KQ...ST_WANTED.html
                        • Originally posted by gurdal View Post
                          1 mH 15 MH
                          This information is correct, I do not understand your experiment with the coil...
                          The data for the coils DD 27:
                          TX - 75 windings, 0.45mm wire, diameter 200mm.
                          RX - 160 windings, 0.27mm wire, diameter 200mm.
                          • Hello I saw osciloscpe signal on
                            http://www.geotech1.com/forums/showt...wanted&page=13
                            I did not understand where is the control points on Schematic to obtain this signals
                            if somebody show this points on schematic and explain how to use this signal to obtain better performace , I will be glad
                            Best Regars
                            Bayram gürdal
                              Best Regars
                              Bayram gürdal
                              SLOBO said: The first picture is the tx and rx reinforcements after the first operation measurements were made with two sensors per channel, the second tree and the phase shift between the rx signals at 1,2 and 9,10 pin 4053, fourth and fifth image signals output from 4053 (4 and 15 pin), the sixth image is the main rx signal.
                              • SMW
