Whites Surf PI schematic
The VDI circuit will only work with a VLF detector, as it relies on the input from two samples taken 90 degrees apart. From these readings the phase-angle (and hence the target ID) can be determined. The Surf-PI operates in the time domain, and cannot supply the required information necessary for target ID.Originally posted by paku View Postthis surfmaster can connect with VDI or not
with my surf pi detector i used two piezo elements in some ear defenders which i used as headphones and really loud volume without need of any transformer...nice sharp audio.
No problem, seek a transformer like the one in the picture, and measure windings resistance. The winding with lower resistance goes to the speaker, and the other one is connected to your machine instead of a speaker. In effect you get a speaker of a larger impedance, and because it is driven with current, it will be louder.
Alternatively you can seek a 50ohm loudspeaker and use it without a transformer.Attached Files
You can use a transformer from an old transistor receiver, and make sure to connect a speaker to a low impedance end. Works for me in another project.
allright thanks bernte_oneOriginally posted by bernte_one View Posthello paku
well done
mix clear laquer or paint (acrylic or epoxi base) with graphit powder and use this as shield
if you dont want to by clear paint
use acetone mix this with styrofoam ( search Q-dope) and add graghit powder (you can measure resistor with meter around 200K setting)
Best Regards, Paku
hello paku
well done
i guess you can as long that you get the transistor pin outs correct
hi
Can I use other transistors instead BC337 and BC 556 ?
