Originally posted by Virdi_248
Whites Surf PI schematic
What value are these Potentiometers?
Volume and thresold ?
white surf pi schematic
Thanks the schematic is different than my SMP pi
I want to replace the speaker with headphone jack. They have to make modification to the circuit.
This is the pcb of my surf pi detector.
My English is bad sorry.
Thank youAttached Files
SMP pi problem
Dirceu, I have a SMP.it has 4 pots, I put it in a metal box at first
it did not work very good only buzzzed. i found that if any pot
touched metal box it would only buzzzed.if your SMP PI is in a metal
box, try it with no pot touching metal, a ground wont work.
Frank-s
DIRCEU, I had the same problem with SMP-pi. if you put SMP in a metal box and all 4
pots touch metal box, it wont work very good.Make sure that the pots dont
touch metal box.
Frank-s
Sure it's not the filter integration time coupled with the number of pulses the target is "hit by"? What I mean by this the Surf PI has a relatively low ppr so less eddy will be induced into the target if the coil is moving fast. "upping" the ppr to around 2.5k or even (scary music) 5k makes a MUCH better machine, but you need a lightning fast coil or else the whole thing just "smears" into oblivion.
It's ALL about balancing, Gain, PPR, integrator time and coil speed (mine now exceed 2MHz) in some cases.
Please read the forum rules -> Basic Rules of the ForumsOriginally posted by Kvrna View PostOlá Dirceu, sei que faz alguns anos que você tocou este projeto.
Estou tentando identificar a algum tempo no Fórum qual projeto farei.
Em parte porque faz algum tempo que fiz eletrônica e não possuo grandes recursos para testes... apenas um multímetro.
Neste post você menciona o Surfmaster Apberg's, o que é ótimo, mas ao procurar pelo modelo encontrei diversas modificações, mas não acertei em achar o original.
Você ainda possuí acesso a este projeto? Sabe se seria adequado para uso também na praia?
Agradeço se puderes me fornecer orientações, é um sonho de infância ter um detector de metais e agora quero tocar um projeto em frente.
Um abraço, espero que vejas o post.. =)
its already there, try taking the meter feed line from after the vco, instead of before, like an audio meter, the louder the squeal the further the meter moves.
i had adapted the gold scan meter for use in the minipulse, but i'm going to completely re-think it now and try running the meter of the vco output, i understand that most wont have any interest in this, but thats ok, it wont be straight forward either, but i have dc meters, and ac audio ones as well, if i can figure out a way to post hand drawn schematics i will put in its own thread.
as a person who's hearing is not standard, i can see a use for a pi depth meter, maybe you could use a vco to drive an analogue scale.
You can of course add an analog meter, but this will only show the amplitude of the received signal. Since the Surf-PI has a one-tone output for all targets, this might be beneficial as a depth indicator. For the PI detectors that have a VCO-style audio output, like the Minipulse Plus, there would be little point adding a meter.Originally posted by paku View Posthow about analog meter
