Ok, i ll try your recipe. Do youthink this could be my problem, that cuses my detector to sound everytime i sweet it to the rigth, sometimes to the left, with no metal close?
Many thanks
Nelson
Hi! NELSON
Yes I do.
I'm using a very simple magnetic earphone, but I am thinking in add to output the Ivconic's TGSL audio.
Best Regards
Very good results !! Hope you find lots more good finds!
For speaker you can also tray to use a piezo speaker, it is not so load but if you place it in a headpone (cheap earprotection style) it is also easy to make it waterproof. Look at the way the waterproof detector have made them. If you use a litle audiotrafo (old transsitor radio) the sound for a piezo speaker gets some louder.
Many thanks
Nelson
Thanks Dirceu.
My surfmaster, have a few things to solve like:
1.- The detector sounds with no metal close, verytime i sweep the coil, normaly to the rigth side.
2.- When i try to adjust the trimmers on pcb, sometimes an oscillating detecting sound comes thru the buzzer, up and down, then i reduce sensitivity until this sound comes just like a hum, but detection range is reduced.
3.- What i notice today is that sound thru the buzzer comes very loud and clear at maximum volume and also i had found that when you low the volume, detection seems to be more sensitive. So may be my problem is with the buzzer and i must change it to a normal speaker or headphones. Any comments on this.
Well, thanks for your coil data. This weekend i will try my surfmaster again.
Kind regards
Nelson
Thanks Dirceu.
Kind regards
Nelson
With my first coil was the same thing then went up to reduce the wounds and measure the distance from targets in each reduction. For me 1.6R.
Under this point the mosfet starts to warm much.
Wire diameter is 0,6mm
Inductance is arround of 165uH.
Put a trimpot instead of damper resistor for choose the best value.
You have done an excellent work.
My surfmaster is working fine, but not so close has the one you made.
I think that my problem is the coil, cause i had checked the pcb and componets twice and everything looks fine to me.
So if you can post the wire size of your coil, will be very helpfull.
Nelson
Many thanks! NELSON
Nelson
Recently I finished my SURFMASTER APBERG's Version and work very very good.
Results in air:
1 euro coin = 37cm
small gold ring = 28cm
coke can (allum.) = +_ 1 m
(All refers at final audio detection)
I made the coil with 19cm diam. planar shape 1,6 Ohms 20 turns. Don't remember now the wire number I used.
I tested it at a beach and I found 8 USD in coins of my country; also one gold ring, one silver ring and one little silver medall. This during 3 hours of researching.Its very good! like a fishing
Results in air:
1 euro coin = 37cm
