The 2N3906 is a PNP transistor and BC337 is NPN, you can replace the 2N3906 for BC556, BC557 or BC558, this transistors are the same type PNP, and the parameters are closer than 2N3906.
Be carefull with the Pins in the "BC" transistors are diferent from 2N3906.
I you see the 2n3906 with the flat side up, the pins are (from left to right) E B C
The "BC" transistors,seeing with the flat side up, the pins are , (from left to right) C B E
I hope this information can help you
Be patient.
Escarabajo.
