Full m/lab SD2000 schematics
To replace the LM394,use a SSM2212,its in a smd package though, not thru hole.
Originally posted by GOHO View PostI really appreciate the help but im still confused. I understand the Schmitt trigger and the components but on this schematic which is which, AND / NOR ?
[ATTACH]53982[/ATTACH]
Thanks!
Do you mean the logic symbol ?, they are shown at bottom of schematic
The CD40106B device consists of six Schmitt-Trigger inputs. Each circuit functions as an inverter with Schmitt-Trigger input.Originally posted by GOHO View Postwhich is which? 40106 = AND 4093= NOR?
The CD4093B consists of four Schmitt-trigger circuits. Each circuit functions as a two-input NAND gate, with Schmitt-trigger action on both inputs.
40106 and 4093? just add CD. CD40106. CD4093.
also HEF, also MM, HCF, etc.
MC140106. google more.
Thanks!
What about the AND / NOR? Any part numbers? Are they individual AND/NOR ICs? On the SD2200 PULSE CCT...
Thanks Again ?
Hello Andrei
Nice job on the tran.png file,makes comparisons much easier,the TP0610K is the same fet as the SI1021R,compare the two datasheets,the TP0610K is in a sot23 package,much easier package to work with than the SI1021R.
Also the IRFB4020 fet is the same fet i use for a TX fet.
I also found one TP0610K transistor, it seems to be not much better than zvp4105, but it is affordable and costs a penny
Hello ZED!
From power transistors like good irf640, IRFB4020Attached Files
- Likes 1
