Full m/lab SD2000 schematics
  • Hello folks, I have a question for you. I am interested in audio schematic for SD2000, Is there any of you who could tell me where I can find 100% correct audio part schematic of SD2000. And is IC 5517 suitable replacement for IC LM13600?
    Best regards!
    • Its all on Zeds schematic. Forget using other schematics, they're laced with errors. Not sure for a good replacement of lm13600.
      • try learn CA3080 and LM13700.
        • Thank you guys
          • 我有一个SD2000,但我发现效果不理想,5克黄金都很难检测,结果是小于GTI2500,不知道是什么 原因,请指点
            • Originally posted by fengzhai01 View Post
              • misleaded. LM13600 is dual while I gave single one both. you need NE5517, you are right. also some tipe I see in fisher schematic... do not see sure marking...
                something FRL510286 -???
                • NE5517 looks almost like a direct replacement for LM13600 and is certainly worth a try. LM13700 has only slightly different internal circuit (but same pinout) so you could give it a try also.
                  It looks like either of the other two should probably successfully fill in for the LM13600.
                  Last edited by porkluvr; 08-31-2014, 05:50 PM. Reason: add some uncertainty regarding the 5517
                  • Its best that you use parts shown in the schematic. I've experimented with upgrading parts which degraded its performance or made it noisy. I can only recommend that you use a ssm2210 in lieu of the lm394 chip in the front end receive. Stick with the original, this is the ultimate diy pi machine with ground balance. Add a variable gain to each search channel and Mario's dds unit will give a substantial increase in performance.
                    • hi mechanic equivalent for diode BAS16 and 1OMQ100 (DIP packages) please. regards
                      • Use 1n4148 diodes where not noted on the schematic. 1n5819 schottky diodes or mbr420 diodes will do. I had a few sbyv27-200 diodes on hand and they work very well.
                        • thank you Finderskeepers
                          • I took g.s project example (DIP packages)20x15cm I run to connect the micro control..... the later micro control connect Click image for larger version
Name:	DIP SD2000.png
                            • Very nice. Lay format file ?
                              • Hello there! found in the Russian forum md4u.ru idea how to replace multiple ICs with processor attiny2313. Thus can be made smaller boards. I made a model of the scheme but it turned out that the times are not accurate. Someone who has more experience in programming you will be able to write a new correct hex?
