Full m/lab SD2000 schematics
  • WM6
    Except if 15k should be trim-pot.
  • detecto
    I think i find one error in schematic and i am actually 100% sure its error as it have no sense.Click image for larger version
    This 330R resistor have nothing to do in this voltage divider configuration.
    Voltage is set to the 0.6 x input voltage and this 330R resistor simply not feet there.
    Can anyone who own SD2000 check?
  • ZED
    To replace the LM394,use a SSM2212,its in a smd package though, not thru hole.
  • liekwang
    Sir anyone knows for a replacement for LM394
  • 6666
    Originally posted by GOHO View Post
    I really appreciate the help but im still confused. I understand the Schmitt trigger and the components but on this schematic which is which, AND / NOR ?
    [ATTACH]53982[/ATTACH]
    Thanks!
    Do you mean the logic symbol ?, they are shown at bottom of schematic
  • GOHO
Name:	SD2200 - LOGIC GATES QUESTION.png
    Thanks!
  • 6666
    which is which? 40106 = AND 4093= NOR?
    The CD40106B device consists of six Schmitt-Trigger inputs. Each circuit functions as an inverter with Schmitt-Trigger input.
    The CD4093B consists of four Schmitt-trigger circuits. Each circuit functions as a two-input NAND gate, with Schmitt-trigger action on both inputs.
  • GOHO
  • kt315
    40106 and 4093? just add CD. CD40106. CD4093.
    also HEF, also MM, HCF, etc.
    MC140106. google more.
  • GOHO
    Thanks!
    What about the AND / NOR? Any part numbers? Are they individual AND/NOR ICs? On the SD2200 PULSE CCT...
    Thanks Again ?
  • kt315
    connections of power pins of the CMOSs' to power lines.
  • GOHO
    Hi, Can someone tell me what these componets are?
    Thank you!
    Greg
  • ZED
    Hello Andrei
    Nice job on the tran.png file,makes comparisons much easier,the TP0610K is the same fet as the SI1021R,compare the two datasheets,the TP0610K is in a sot23 package,much easier package to work with than the SI1021R.
    Also the IRFB4020 fet is the same fet i use for a TX fet.
  • Andrei
    I also found one TP0610K transistor, it seems to be not much better than zvp4105, but it is affordable and costs a penny
  • Andrei
    Hello ZED!
    From power transistors like good irf640, IRFB4020
