Tarsos detector vlf turkey
  • Мощност- ватове!
    Power - wats!
    Напрежение - волтове!
    voltage/tension - volts!
    • Pozdrav Unregistered. Hvala na misljenju sto se tice ovog detektora. Pokusacu da ga dovrsim kad sam vec pola odradio. Posto ne prodajem detektore nego ih pravim iz hobija a vec imam 4 u kolekciji mislio sam da ovo bude 5 detektor. Vise mi i ne treba jer su svi skoro slicni.Ovaj hobi odnosi mnogo vremena i zivaca. Veliki pozdrav.
      • Ja ti rekoh a ti kako ti drago. Humhum lupeta gluposti. Nema veze kolika je amplituda TX-a, kad je ostatak bezveze igrackica. Sto se mene tice moze amplituda da bude i 300vpp, dzaba je bilo...
        Poz
        • Ето ви и Видео тест за Тарсос .
          http://www.savefile.com/files/2087706
            Poz
            Не мисли че говоря глупост.
            • Originally posted by humhum View Post
              Tozi test e pulna pornografia.Naredil choveka nqkvi suvremenni keremidi i varovikovi kamuni i misli,4e neshto testva .Nikakav smisal niama v toia test.
              • hi to all
                please upload the correct shema and (pcb)** for tarsos detector.
                i cant find bf245 transistor so what transistor insted this one will be ok?
                best regard
                • Originally posted by mehdi View Post
                  hi to all
                  best regard
                  Hello Mehdi,
                  All the details are in the previous posts. There were several versions of the Tarsos and some with autotune. Which version are you looking for?
                  BF245 is common and you can get order here:
                  www.digikey.com
                  J107 may work as well.
                  It was fun to build and play with but is only single channel, so not to practical to use.
                  A better project in my opinion (that is single channel as well) is the Volksturm.
                  Much more stable, good depth and practical if you can make a coil.
                  http://www.geotech1.com/forums/showt...lksturm&page=2
                  You can find all the details here:www.md4u.ru
                  • hi dfbowers and thank you for your answer
                    (http://www.geotech1.com/forums/showt...lksturm&page=2) i cant open this link and (www.md4u.ru) this is may be russian site and i dont understand russian language so can i want you send me the shema and pcb of volksturm detector please?
                    my email: [email protected]
                    thank you very much
                    mehdi
                      thank you very much
                      mehdi
                      Mehdi,
                      You can use http://babelfish.yahoo.com/ and translate the entire website.
                      All the details for he Volkstrum are there. Or message KT315 as it is his design
                      You can do the same for the original Turkish website as the details are there as well.
                      I do not have a PCB layout of what I did, just the schematic posted earlier in the thread.
                      Don
                        hi to all
                        best regard
                        I've built TARSOS and is very unstable in the soil of eastern Serbia. Much better and more stable than the "S-1" Sascho Varna (Bulgaria):
                        http://www.geotech1.com/forums/showthread.php?t=15140
                        and http://www.geotech1.com/forums/showthread.php?t=14997
                        • i decide to build volksturm sm but i can not find the companent list and correct pcb lay out ! even at www.md4u.ru !?????
                          can anyone help me? please
                            There are several different versions of the Volktrurm SM. One is posted in the Forum section of www.md4u.ru
                            Below is a modified version that I built. The TL061 is used to ground balance and the pot labeled "Phase" is a ten turn Bourns to allow find adjustment over a wide range.
                              See attachments for 2 different versions. I have not seen a complete parts list but I might have a list of parts that I ordered from Digikey a while back.
                              Don
                              • thank you dfbowers for your help
                                i am going to build it....
