A typical 5V regulator wants 7.5V or more to run. The problem is the extra juice gets converted to heat.
If you had a LDO (Low Drop Out) regulator they need much less to run. The PI TX likes 12V to make some
high field strength. 4 LION cells would give you 16V! 3 is 12V and would be better. Maybe you can mod
the board a bit and use 2 to generate 5V and 3 or 4 for the 12V?
