Originally posted by green
Target response tester
Target Response Tester wired except for log amp. Did some testing to see if it works before trying to hard wire the log amp. Finally got a silver quarter. Eric's traces of clad and silver quarters looked real close. Mine does also, closer than expected. Now to see how the log amp works if I can wire it.Attached Files
Hi Green , sorry to put your thread slightly off track, but I was wondering if you could confirm something for me please, back when you were doing your ground balance experiments to eliminate your bags of dirt, were you simply putting the coil on top of the bags of dirt or were you bobbing the coil up and down ? thanks.
The coil is stationary, bottom up. The bag of dirt is put on bottom of coil. The ground balance is adjusted for no change integrator out, dirt on or dirt off coil.Originally posted by 6666 View PostHi Green , sorry to put your thread slightly off track, but I was wondering if you could confirm something for me please, back when you were doing your ground balance experiments to eliminate your bags of dirt, were you simply putting the coil on top of the bags of dirt or were you bobbing the coil up and down ? thanks.
Added the log amplifier. Glad I had only 1 chip that size to hard wire. Want to thank those that made suggestions when I was trying to learn something about log amps. I decided on the LOG114 because of speed and it would work with the +-2.5v power supply that I use for the other analog circuits. Did a comparison test with the log amp vs the way I normally do it. The two traces the way I normally do it didn't line up but the slope was the same. The 1 layer decays about 1 decade every 4usec both methods. TC=(time/decade)/2.3, =1.7usec. The 4 layer decays about 1 decade every 14usec both methods. TC=(time/decade)/2.3, =6.1usec.
Log amp looking at pre amplifier out, gain about 450 vs (target sample recording-no target recording) (CH1)pre amplifier out, gain about 450 (CH2)amplifier out, gain 9 total gain about 4000. Both methods similar results. Both methods about 2 decades limited by amplifier noise. Log amp, real time the other takes a lot longer. Log amp needs a good no target zero, other method charts difference so it cancels any offset.
Looking at your reply again I see I didn't explain may test method very well. I adjust ground balance(target sample time) for no change at integrator out when I place the bag of dirt on the coil or take it off, similar to pumping the coil. Most of the time distance measurements are made with the dirt off, GB on or off. I have checked distance measurement with the bag of dirt on and off the coil. The bag of dirt on coil didn't seem to effect the signal change vs distance measurement.Originally posted by 6666 View PostThanks for reply, had not thought of retesting with dirt off.
I was going to ask about your intended LOG114 circuit, and wondered if you were going to simulate it in Spice first, as you have the skills. I haven't read the datasheet for the IC, (though I did download it) but I was wondering how best to get round the 0.5V offset for the intended photodiode bias.
How did you wire up the IC ? I've just recently wired up an IC accelerometer in a tiny leadless package, some patience is needed.
Thanks for the clarificationOriginally posted by green View PostLooking at your reply again I see I didn't explain may test method very well. I adjust ground balance(target sample time) for no change at integrator out when I place the bag of dirt on the coil or take it off, similar to pumping the coil. Most of the time distance measurements are made with the dirt off, GB on or off. I have checked distance measurement with the bag of dirt on and off the coil. The bag of dirt on coil didn't seem to effect the signal change vs distance measurement.
Didn't try LOG114 in spice because I haven't earned how to add other spice models to LT spice. The TRT circuit is the first one I've put together without having to modify the circuit or fix a wiring error in a long time, maybe the first time. Could attach schematic if anyone is interested.Originally posted by Skippy View PostI was going to ask about your intended LOG114 circuit, and wondered if you were going to simulate it in Spice first, as you have the skills. I haven't read the datasheet for the IC, (though I did download it) but I was wondering how best to get round the 0.5V offset for the intended photodiode bias.
Including a picture of how I wired the LOG114. Pin numbers are reversed, pin16 adaptor is pin1 of LOG114. Go clock wise, pin2 LOG114 not connected. Messed up pin 2 adaptor but it didn't matter because I don't use that op amp.Attached Files
Some scope traces with a silver quarter at 3 different Tx width's, 1/2A peak constant current and 1A peak constant rate. Probably easier to see difference if they were on the same chart.Attached Files
How did you wire yours? I wired an IC accelerometer in a tiny leadless package at work a few years back without the adapter. Was thinking might have to make modifications to the wiring this time so I used the adapter so I didn't have to rewire to the log amp.Originally posted by Skippy View PostI was going to ask about your intended LOG114 circuit, and wondered if you were going to simulate it in Spice first, as you have the skills. I haven't read the datasheet for the IC, (though I did download it) but I was wondering how best to get round the 0.5V offset for the intended photodiode bias.
Some targets cut from an aluminum can side, LOG114 output. Looks alright above 25mv input. Not sure the slopes are correct, need to check decay response with known input. Maybe something similar to spice model, discharge a capacitor into the input.Attached Files
Do you have any thoughts on why the errors occur when the input is low, ie. below 25mV ?
I was thinking it's simply a DC offset, that becomes more obvious as the actual DC signal level falls off.
But I did wonder if it was due to a slower log-amp response at lower input currents.
I guess ideally you want to drive the log-amp hard, so that these errors become less significant.
And regarding my accelerometer build, it looked surprisingly similar to your logamp, I stuck it on some copper-clad board, knife-cut with a simple pad layout. I'll try and find the pics I took of it.
I would assume the 40mm square can target would give the most accurate TC value (it's dimensions will be more precise, the longer TC is easier to measure accurately), and the other smaller samples should be in direct proportion. The fact that they're slightly high is curious. A more thorough experiment would be to test many (8, 10?) different size samples, and plot them on a 'straight-line' graph.
I think it's either speed or the no target signal being not quite zero early in the decay like you suggested. Going to try to discharge a capacitor into the input with discharge TC of 1, 3.3 and 10usec time constant.Originally posted by Skippy View PostDo you have any thoughts on why the errors occur when the input is low, ie. below 25mV ?
Charted the silver quarter again. The 300 and 600usec Tx width's with constant rate looked different than constant current with the scope traces I posted awhile back. Wanted to retest and chart to see if the same thing happened. The silver quarter has a TC around 150 to 160usec. Any thought why the 300 and 600usec Tx width is about the same constant current but different constant rate?Attached Files
