Carl, After reading all 8 pages I got to doing some tests of my own and over here in the UK I can air test a 2 pence piece which is a low grade copper coin and I got a repeatable signal at 16" or 400mm so i then got a small plastic money bag, 1 coin weighs 0.2248ozt and the 50 i used for the test weighs 11.240ozt so when i waved them in front of the coil
I got a 2 way signal at 24" or 600mm and using the 3rd tone on my machine I could up set the treshold at and beyoned 28" or 700mm, these low grade copper coins will rust and depending on the date give massively differant VDIs
All these coins would fit in a cigarette pack, I'm always doing tests of some sort like
the thin frame on my glasses my detector will pick them up 45" or 1150mm,
my Zippo is picked up at 24" and up to 28/29", I hope this helps,
John
John
