Elektor's Tank Locked loop oscillator
4046's are trouble in real life, so probably are in simulations, too.
Does R10 go to ground , or -5V ? Just a thought...
Does SigIn need protection, like two diodes clamping it to +5V / -5V ? Seems you may be feeding it with more volts.
It may be an idea to split the circuit up. Get Spice to feed in a sine-wave sweep directly into the coil drive circuitry, and see that it actually drives the coil, showing the resonance on the LC circuit. About 3.5 V rms into R8 would be about right.
Then force the 4046 VCO to mid-range ( input to 0V ) and get it to produce whatever the LC circuit tuned to . Then try closing the loop.
Are you running this with a CD4046 ( regular 4000 series ) or a 74HC4046 ? ( 5V TTL type ) ?
They aren't the same, and clearly the PSU requirements are different.
Gotta be suspicious about the original schematic, with the resistor value of 100R incorrectly shown on the TX drive ( R6 ). What else is wrong??
It is discussed here: https://www.geotech1.com/forums/foru...ator-front-endOriginally posted by Gwil View PostCan anyone explain to me what is gained by including a phase locked loop in this circuit?
I don't think I've seen one in any other coil driver design. What problem does it solve?
Thanks.
Yes, I did not see that. The 100R is obviously wrong. The original magazine article shows correct values as far as I know. But that's beside the point. Recently while digging through pile of scrap, I found some PLL chips on an old junk board and Elektor's circuit came to mind.Originally posted by Skippy View PostAre you running this with a CD4046 ( regular 4000 series ) or a 74HC4046 ? ( 5V TTL type ) ?
