VLF MD with digital signal processing : Bee-Buzz 1
  • Hi all,
    I am doing sanity check on my experimental detector code (Win32 MFC App).
    I even have implemented an LCR meter, which is way more accurate and has much more resolution than my bought LCR meter for over 200 bucks.
    :whew
    I have to get rid of all the features and start with a clean project. I have replaced two threads and left the old codes unchanged.
    This is a task for weeks before I can show some real measurements. But I am making some progress.
    • Hi all,
      it seems, that I have really plenty of CPU horse power for the detector software. The CPU load is less than watching a movie on the Tablet PC (approx. 2 % CPU load ). The external USB sound card will suck more energy from the battery of course.
      But if I use graphics display with plenty of infos, wave forms, spectrum analyser output and more, it increases up to 35 % CPU load for 50 frames per second display update rate. Unfortunately, the windows GDI (graphics display interface API) isn't efficient.
      Oh well, it makes sense to keep some old features and add several modes for detecting mode with less power consumption. And a FFT spectrum analyser, a Super-Duper-LCR-meter is required for setting up the detector too.
      • Hi all,
        the ultra-low-noise pre-amp issue is back!
        Get "The Art Of Electronics", Hill-Horrowitz, 3rd edition.
        There are some very interesting topics there. I'm going to realise the 0.2 nV/sqrt(Hz) input voltage noise density pre-amp!
        • Isn't it time to change the topic's name?
          • Here is the link to a free download
              https://archive.org/details/the-art-...ed-2015_202008
              Thanks!
              See on pages around 500 and more!
              There is a list of npn and pnp transistors with noise specs.
              Long live Zetex & Diodes for making these transistors.
              I will look at spice files for best candidates with lowest Rbb (base resistance).
              • Hi all,
                I have purchased several parts for the next step:
                - ZTX 851 (npn), ZTX 951 (pnp), ultra-low-noise transistors. Only these interesting parts are available from where I buy parts.
                - enough enamelled magnet wire 1.0 mm diameter for the choke L1
                - Blue-Tooth keyboard and Blue-Tooth numpad for my Tablet PC
                and other parts.
                Re: Blue-Tooth numpad
                I'm going to remote control the detector software on my Tablet PC with this small numpad. The software will be adapted to work with this kind of keypad.
                The software part is quite time consuming. I have to change a lot of things and re-implement the whole detector software. And I have a glitch problem on Windows 10 OS with the Sound Blaster G3. So I have to re-write some critical threads once again. If I am finished with these critical parts, it is time then to show some frequency spectrums. And decoded results. And how to solve the GB problem (yet another WBGB? ). And whether we need an ultra-low-noise pre-amp.
                Cheers,
                • Hi again,
                  the glitch problem does seem to happen on the Sound Blaster G3 only. With Sound BlasterX G6 there isn't any problem. Could be a bad driver problem. Or my own software, which I should check this or at least solve this issue.
                  G6 is obviously optimized for up to 20 kHz output (audio range). Snake oil advertising. :whew
                  Above it is getting quickly worse (up to 20-30 dB worser) and we have to rise the RX signals well above the noise floor level. This is the reason for the pre-amp need.
                  • If you want a good, fast FFT 'C' library to use in your application, then I have used 'FFTW' in conjunction with QT under Windows with very good results...
                    It's a native 'C' library so should work with just about any processor, although it does have optimizations which can take advantage of various processor specific features.
                    A fast, free C FFT library; includes real-complex, multidimensional, and parallel transforms. Benchmarked against many other FFTs.
                    • Originally posted by Olly View Post
                      Thanks,
                      I know this site.
                      I also have many different implementations of FFT. Even for a realtime DSP with fixed floating numbers (using the efficient MAC opcode; I have coded this for over 20 years ago or so). Also an AI inference code for the DSP (neural network). Anyway.
                      I have put in the reference c-code a simple version for block sizes of power of 2 (in-place complex FFT variant). This is doing still a good job.
                      • Hi all,
                        no chance to get the Sound Blaster G3 to work on Windows 7. No drivers available. It isn't down compatible and won't work even at USB Audio 1.0.
                        (Creative, go to the hell!)
                        I have to wait for the Blue-Tooth keyboard. I can't work efficiently on the damn touch screen to work on the glitch problem on Windows 10 tablet PC and G3. And there is only one USB-port and this is occupied by the damn G3, so I can't attach an external keyboard.
                        I don't have an USB hub too.
                        BTW, my old Asus Eee PC 901 with Windows XP is out of order and must be repaired:
                        - the keyboard isn't working anymore
                        - CMOS battery is empty and must be replaced
                        - 4 Li-Ion batteries must be replaced too. They are totally damaged.
                        The Eee Netbook PC is a nice portable detector platform and I wan't to use it too. This is the further reason for, why I need the Blue-Tooth keyboard and numpad too.
                        So I want to check, whether my detector software or the hell's Creative driver software on G3 is buggy. I hope, that it's my fault so I can fix it easily.
                        Me :kick Creative!
                        It is not a good day. :wall
                        Cheers
                        • Hi all,
                          this is my Asus Eee PC 901. It's alive now.
                          I have attached an external USB keyboard.
                          I have changed the internal CMOS battery.
                          I have repaired the Li-Ion battery. The contact between two cells was totally corroded. I have cleaned it and put a clean washer between the two cells. The battery is charging now. I hope, the 6 (not 4) cells are still good enough. Anyway, I have to change them in the future.
                          Cheers
                          • Hi all,
                            good news: The Li-Ion batteries on my Eee Netbook PC seem to work. It was apparently a production error: They have simply forgotton to solder the battery strips at the corroded connection.
                            There is an another Windows XP PC, which isn't working anymore too.
                            The most interesting part in this project will be the ground balance and discrimination. Note, that we have a lot of multidimensional information: Complex output Real/Imag or Magnitude/Phase, for each interested frequency bin. And we have two transmit frequencies at the same time. And we also measure the TX-coil as a reference signal at interested frequency bins (at least to get correct phase relation of RX to TX).
                            Why I want to use the dual frequency driven resonant TX tank?
                            - low Z (impedance) of the TX-coil -> we can push more current through the TX coil, TX-current will be amplified
                            - high energy efficiency -> energy will be recycled on resonant LC systems
                            - more info -> better GB and discrimination
                            This is going well beyond any simple VDI calculation. The GB and discrimination gets very easy, after I implement and show some visualisations of the calculated data. But this is a long way to go yet.
                            Cheers
                            • Hi all,
                              my old Windows XP PC is now running too. I have full access to my old project files.
                              Again, problems with contacts and aging plastic. I had to remove all connectors from the main board and plug in them several times. And I had to clean and repair my CPU water cooling system. Everything done now.
                              I can focus to the software coding part. The glitch problem with G3 on Windows 10.
                              Cheers
                              • Hi all,
                                this is the simple loop-back test on Sound BlasterX G6 running with 24 bit resolution @ 192 kHz SR . Line-out has 3 kHz (left-ch) and 12 kHz (right-ch) signal, which is fed into Line-in with a stereo cable. So you don't see any RX signal. It is a basic loop-back test to check the SNR of the DAC/ADC system. You see, that in the frequency region up to 24 kHz, the average SNR is at -120 dB (this is quite good). Up to 48 kHz it degrades a bit. At approx. 54 kHz, there is an external noise source coming from PC I think. The SNR arrives -100 dB at approx. 75 kHz. The higher the frequency, the worser the SNR. I say it is a snake oil from Creative.
                                Click image for larger version  Name:	FFTSoundblasterXG6Loopback.png Views:	0 Size:	101.2 KB ID:	435002
                                My block/frame size is 1024 samples (for FFT reason). I get 187 frames/s from the sound driver. And process all 187 frames. The display rate is reduced to 10 frames per second.
                                The blue line is the FFT spectrum. There is a thin blue line indicating the average FFT spectrum.
                                White trace is left input channel signal. Red trace is right input channel signal.
                                Sound Blaster G3 is much much much much worser!
                                Cheers,
