TR locator / 2 box
just there will be order on 50 pcs for TF900 or DEEPERS 10DD pcbs i will do. but i do not see wishers.Originally posted by kece hon View Post
i did, three times actually ; i followed most of it to make mine
i remember you commenting on it a lot did you make a fully functionnal one back at the time ?
However, if you ask me; of the "dedicated" 2box, TM-808 is certainly the best
TM-808 is different sch than TF900. TF900 is sure TM-800, TF600 as well. but TM-808 was took from 5900 6000 DI PRO SL sch static part.
разработчик i do not know how to write in english took this part but forgot that DISC mode, it must be CAVITY mode in TM-808, has not needed depth.
this mode was deleted by them from last TM-808s.
Thanks a lotOriginally posted by GeoMax View PostHello Kece Hon,
Thank you , The windings in the original T/R Locator are well wound. Your coil needs some work. This could also be one of your problems. I'm not entirely sure, but doesn't the original T/R Locator coil also have a shield?
about the windings , ill see what can be made ,
i remember that its made with no shield, works fine without it
sure the TM808 , when i looked at the components and the PCB it seems way hard to makeOriginally posted by kt315 View PostHowever, if you ask me; of the "dedicated" 2box, TM-808 is certainly the best
them this mode was deleted from last TM-808.
have upgraded the schematics since then ?
most of the electronic pieces are very hard to find , there is also some double coils ferrite ...
i'll stick to the two box , if you could suggest any thing , that would be very generous from you
if any one could provide some voltages values in the Two Box.... PCB lay file down in attachement
Thank you
