Originally posted by Ultimate_Haze
the frequency is wrong... too low.
Must fit in 14Khz to 14.7Khz (about) to get it work and reasonably well.
Try to stay in the middle or in the range at least.
So, try to match TX frequency first... add turns if needed. The device is strict on that param about proper disc etc... also at lower freq you lose efficiency at voltage converter though you have small variations and not so big issue in your case about that.
If wanna make it run on higher or lower freq you must change components expecially at disc section... otherwise don't work any good, cannot balance etc.
Kind regards,
Max
D27
Can you tell me with perfectly balanced coil how is Vp-p on pin 7 on U101a?
