TESORO GOLDEN SABRE
  • WM6
    Hi Max
    regarding this movement. How can we explain that some coils/MD give away acoustic signal only in one way movement (e.g. right movement) on return movement (e.g. back to left side) it keeps silent. This repeatedly as rule not only once.
    thanks for kindness,
  • Max
    Thank you ivconic I very appreciate your knowledge and experiences, rely uppon your help in future too. Thanks.
    zzy one more outline maybe this cross section of active coil is closer to explanation your observation.
    Yes... exactly what I mean!
  • Max
    Originally posted by zzy View Post
    Hi,Max
    I sweeping a 3cm coin flat and then tilted nearing till detector beeps in both cases
    My test result is strange.
    i use DD coil.
    when flat, I reach 25cm,
    when tilted, I reach 27cm,
    my test shows that
    so i think WM6 is right.when tilted,the machine gets more deepth.
    fluxlines have maximum coupling with target when it's tilted 90°.
    could happen so if your coin to coil diameter are "near"... please don't misunderstud me... I'm not talking about 20cm diameter coins... but of some 3cm one and e.g. a 20cm coil.
    What I mean is there are conditions where, expecially with smaller coils like 8'' or 5'', you can detect a very large coin better if tilted 90° than flat. I know that... and it depends on fluxlines there and effective surface of target exposed to them... that could be higher tilted than flat in some cases.
    I meant the maximum performance are flat at "far" from coil... say that you have a coil of 10'' diameter (25cm) I mean you move an e.g. 3cm diameter coin at 1.2-1.5 diameters away (30-37.5) and detect it.
    In this "far" area you'll get better results with coin flat... and much probably don't detect it if tilted 90° respect to coil.
    Why this ? Easy: fluxlines patern is different "near" respect to "far"; in near conditions more "lateral" coupling exist and that's why you detect better your coin.
    If you tune device to extreme sensitivity... and go in "far" conditions you'll see just flat coin detection: try it.
    Kind regards,
    Max
  • Max
    Agree Max. Thank you for explanation.
    Maybe this reflect in some better way reality:
    One more question:
    Factory made coils are adequate adapted to MD circuit parameters, suppose at first by inductance L and resistance R of coil.
    When we work out other shape of coils for same MD is hard to achieve both L and R of original coil (cause of wire diameter, other parasite C etc.).
    Usually it is easy to reach one of original parameters whether L or R, but not both at the same time.
    My question is: what is better to follow during other shape coil construction, original calculated inductance or original given resistance of coil? (If we cannot to achieve both at the same time of course.)
    Thanks!
    I agree with Ivconic: when you need make a coil for a particular detector is better mathing well L , inductance, cause this way you get right frequencies at both TX and RX... but also you'll get right phase shifts when properly tuned. Both things are really important in VLF MDs cause very often there are filters and expected frequency range where device works good... outside which it works bad way or just don't work; also about phase shift you need good alignment to original coils value with no target near... otherwise you'll get bad/strange disc behaviour in disc mode.
    Resistance is a key factor too cause you can alter much Q factor of coil with diameter of wire selection and total resistance value change: that's why it's often better use larger diameters on large coils.... more lenght at each turn and you need thicker wire to preserve right Q on coil.
    The problem with most designs is that they require strict L matching and hi Q too and this leave really few freedom for designer when try to make very large coils or particular shapes... but here we have top class designers/experimenters ...so it's not a big problem.
    Also, I noticed too that on some Tesoro's designs L is not so critical as one could expect...if frequency at the end is right (so just changing caps if required) but much more important seems is phase shift between TX/RX.
    Kind regards,
    Max
  • ivconic
    I have looked again at your pictures and I noticed that you have leaved too wide gap in TX.Why?As I can remember in magnum this were 1,5 cm?
    Am I right?
    No special reason. I was too lazy to pay attention on every detail...For me not important at all.
    Magnum...do i give a shi. about Magnum?! Of course not. I do make my own coils without watching other things...Simply i dont bug myself with those.
  • ivconic
    Hello,
    I cant understand this.Until now I have used 2 together shielded cabels wired the way showed on your picture.But now when I read this I see many changes!So how to wire?TX and RX stat points to 2 cores,shields of cables and faradey cages all together.But then where to conec the ends of RX and TX?And on other hand how to wire to PCB?Cores to upper points for TX and RX?And leave ground point for RX empty.And conect shields of cables to TX ground point only?
    If you draw a new clear picture I will be very greatefull.
    Thanks.
    p.s.I went prospecting yesterday with my TGS and havent found a single coin,but many rubbish colored ithems and a few large Irons afcours.But I have noticed that when I go near a high voltage line,my detector is not working!~!When I pick up my coil I can hear the electricity passing buy!!!A little bit scary.....The problem is that this is a good spot and I cant took advantage of it.
    This time I had a feeling that my detector is not penetraiting!!!The land were just prepared for seeding and there were hugh level differances!May be because of this were the poor performance?
    Look my sketch again and read my words again. My words justifying my draw. So what is not understandable there???
  • WM6
    I will take freedom to make some notes here, on this;
    yes it is right question!
    L is value included in formula to calculate oscilator frequency along with C, since most of oscilators here deal with LC coils.
    So main parameter we must obey here is L for sure.
    R is also important. Unproper load could easilly distort RX opamp and lead it to saturation or...make inputs "deaf" and choke induced current. So obviously R should reamain in some limits, i would say; approximative to original resistances. On TX side also unproper load could easilly saturate transistor and produce lot of harmonics, and vice versa, easilly choke it and stop oscillations or cut amplitude to unuseable values. Also current drain rises significantly.I spotted elegant solution at Garrett Scorcher coil where serial resistor is used in manner to prevent unexpected variations in amplitude, mostly, along with other function there.
    At TGS we have 2 x 5K1 resistors having limiting role there. I experimented with those values and discovered that down to 3K3 amplitude and induced current remain unchanged. Although it would be better to strictly use metal film resistors there with high Q, since some low quality resistors do affect amplitude at opamp inputs.
    So when making coils i usually do respect L strictly to exact value and R approximately with 10% jitters...
    Recently i spotted another elegant solution at RX front end. At Fisher 1265 LT1007 is used with adjustable gain...very nice solution.Also could give some ideas and lead to more experiments...sheeesh! Neverending story!!!
  • tiktak
    Hi
    OK, i got first,preliminary results;
    first i have to say, nulling omega coil turned to be much
    more difficult than DD coil???!
    (Last time i made omega coil was for MD3007 and i didnt used
    present method by measuring induced voltage in RX coil)
    It need 1/10mm to drop to 0 volts or to jump to 20-30mV!!!??
    After much effort somehow i managed to achieve excellent null.
    At 200mV range it says 0.01...more than good!
    OK, than i resoldered RX wires from miliviltmeter to TGSL.
    WOW! What a stabillity!!! I dont beleive my eyes!!!
    It is very,very stabile coil!!!! Superb over DD coil!!!
    Discrimination is P E R F E C T !!! Perfec,perfect!!!!
    Ferrite rod is absolutelly invisible for this coil even if i
    lower GEB trimer much "down" from usuall value, usually trimmed
    with DD coil.... Usually, when DD coil nulled well, there are some
    mum "cracks" on ferrite rod with trimmer on 60%. I usually left that
    way and later turns detector acts pretty well on soil.
    But now, with this coil - not "cracks" at all! Trimmer at half - no
    "cracks". Thin silver coin - yes, detected loud and clear!
    Wow.
    Ok, depth is lower than 27cm coil. 1 Euro coin detects very easy at 24cm
    in air. 1.5cm nickel coin at 28cm.
    Considering diammeter of this omega coil - 21cm, i think it is not
    shallow comparing 27cm DD coil, not at all.
    Next thing i'll do is to make 27cm Omega coil and than see real differences.
    Bit now, i left out of wire, so this will wait for week or more.
    But discrimination is really perfect. Large iron claws - absolutelly invisible
    in disc mode.
    What to say more? Need to finish it and than perform full test outdoor on the
    real field.
    Until than...
    Regards Max!
    Am I right?
  • tiktak
    Hi
    Hi Ivconic,Now,I null the coil at 17mv VPP,the sense is good.
    but I have another question,please help me.
    Just like you had said i use two separate coaxials cable. the question is
    if i tuch the cable,or bend the cable,the machine will beep.it make me crazy.
    Regards and thanks for your support.
    Here is my coil and cable.
    Shouldn't!? Try to adjust GEB trimmer a bit. RX is connected to gnd in coil but not on pcb. Both Al foils are connected togather as well as both cable shields - in coil, but separatelly at pcb, without RX on gnd (as told before).
    Hello,
    Thanks.
  • zzy
    So strange
    Hi,Max
    i use DD coil.
    my test shows that
  • ivconic
    One more question:
    Thanks!
  • WM6
    Hi, lines described are not like in real coils: fluxlines have maximum coupling with target when it's flat (like on the left of picture) and minimum when it's tilted 90°, so with sharp edge on normal axis.
    The maximum the surface orthogonal to normal axis and the maximum the flux chained at reasonable distance from coil.
    Kind regards,
    Max
    One more question:
    Thanks!
  • ivconic
    I test like at left side: coin flat vs coil, move left to right or right to left , so orthogonal to normal axis of coil and parallel to windings.
    Same as me..
  • Max
    [quote/]I move up and down,it seems got more deeps,
    and i make the coin upright.it got more deeps too.
    [/quote]
    You can notice it very easy... just try sweeping a 3cm coin flat and then tilted nearing till detector beeps in both cases: when flat you'll reach maximum performance, so depth on air; when tilted like on the right you'll get minimum effect at far distance (cause flux lines intercept just minimum area on conductive target so current paths are minimum size too, and currents very low).
    On soil... stuff is different cause also a tilted target could give good signal if e.g. developed (like iron) some "halo" (salts and compounds all around soil matrix near metal). But this happens just spot and not always.
    Kind regards,
    Max
  • Max
    Hi Ivconic and Max,
    How to test the TGS sense?
    this picture is my test result:
    [ATTACH]4521[/ATTACH]
    how do you test the machine?
    Kind regards.
    Hi zzy,
    I test at each cm if sound or not... then refine to get maximum indication with resolution of 1/2 cm.
    I use also second method (right side) moving front/back larger objects like coke cans or similar e.g. iron or copper plates.
    The first method is much like you do when search on soil... sweeping left to right and reverse. The second method is good to understand if device as some inertia or similar... or, in other words, if it's fast or not.
    The first method is good for small stuff , like coins... cause you can evaluate also the spatial sensitive area in front of coil... like described too in Tesoro's manuals for detectors similar... (bandidoII).
    The second method is good to test with ferrite too... I use it much for little tests with rods to see how much detector is influenced by "height" variations in "magnetized soil" (emulated by ferrite rod effect).
    Sure... for depth measures the first, leftmost, method is the one you have to use I think.
    Kind regards,
    Max
