TESORO GOLDEN SABRE
  • Ropcsika
    Originally posted by paku View Post
    Ok thanks and what is K1 K2 K3
    Discrimination switch connection point
  • paku
    Ok thanks master
  • eduardo1979
    K1, K2, K3, is the switch to the Disc and All Metal modes. K1 and K3 are connected to pins on the switch side, and K2 is connected to the central pin of the switch.
  • paku
  • eduardo1979
    That is correct. This is the discrimination potentiometer.
  • paku
    i need help how to wire this potentionmeter on this P10 P20 P30 is that right or not on my picture
  • eduardo1979
    VDI LCD 2x16
    [ATTACH=CONFIG]24487[/ATTACH]
    Can i put This LCD To TGSL-Edu
    If Can, How To Connect it
    if any one have tutorial about how to put this LCD to TGSL-Edu Can You Share Here!
    VDI GEOTCH
  • paku
  • satdaveuk
    Hi
    Nice build,
    All you need to do now is install the electronics into a metal housing make sure there is good bonding from earth to coil plug and pots and all should work well.
  • Zs_21
ID:	335910Click image for larger version
ID:	335911Click image for larger version
ID:	335912 here some pictures,soon i got the video.
  • Davor
    Can you make a video to show us what is going on?
  • Zs_21
    Hi all!
    I built the TGSL and there is a problem with it.When I touch the Ground balance or Disc level pot cable,have fail signal.Im paird the resistors and capacitors.
    pls help (sorry for my bad english)
  • dfbowers
    Originally posted by mrmr16 View Post
    Hi to all
    what is deep sensetive of TGSL or what is last deep sensetive of tgsl .
    thanks
    That depends on many things. The easiest thing to do is buy a kit from silverdog.
    Then you have coil size and type, ground conditions and ambient noise which all have a very significant impact on final results. Then, finally, it depends on whose hands you put it in.
  • mrmr16
    Hi to all
    thanks
  • golfnut
    Cheer Dave,
    I dont have a TGSL, just IDX.
    can you put a pic of your gold!
    S
