Originally posted by akademiker
Hi akademiker ,
Didn't you mixed up the bottle of acid and the bottle of glue ?
If you find enough wire for the Rx coil you also can try them without / before shielding for testpurposes.
I'm aware that the coils must be shielded for field operation but :
- see the big difference in phase shift when nulling compared to shielded coils ( at least for me and it seems that Mullihaka has the same problem ) http://www.geotech1.com/forums/showt...744#post117744
- Same for the residual voltage : from a few millivolts to volts
These are my observations at this time ...
Still my question remains : what is there to gain with different types of shielding
Perhaps a greater distance between shield and coil ?
Today I've stripped a vga cable with (I think) mylar shielding inside for my next experiment
Good luck with your coils
Dennis the Mennis
and worked like some kind of capacitor without causing a short circuit. I will never use glue again.
) because they are dipoles flipping around...
