Originally posted by golfnut
One thing you must understand is that, even though the RX coil is tuned to 16kHz, the signal received is still 14kHz. Think of the RX coil / capacitor as a filter. You put 14kHz in, and you get 14kHz out, albeit shifted in phase and a lower amplitude.
Since the sample pulses for the synchronous demodulators (analog switches - JETs, in this case) are triggered from the TX oscillator, the RX signal needs to be phase-shifted to allow correct sampling of the in-phase and quadrature components. This is the reason for the different frequencies. It has nothing to do with creating an intermediate frequency, as per superhet designs.
(those who can't do, ...). But if they ever offer degrees in metal detectors, I'll try to get one... BTW, your explanations set the standard, your docs have changed the landscape.
