King Cobra PCB
  • #76
    Not cheap really, dear KT315, but main question is: if one of those PCB was populated and checked in real, on working abilities, and what results outcome?
    the schematic is similar to any Tesoro, TGSL, TGS, you have a chance to check all declarations done before in another threads. nothing new. new is only a BOARD. it is a learning platform for all VLF like Hammerhead is the platform for PI.
    • #77
      Cobra
      Can you provide parts list and pot pin out?speaker connection point etc?
      • #78
        ok. have to draw...
        • #79
          Hi KT315.
          Can you help me about your favorite Gold Mountain King Cobra? These days this machine was start to be my obsession. Unfortunately my Proteus can't see some of PCB portions at the picture of the King Cobra you allready post on a geotech. Please if you have some more pictures of this grate machine's PCB, send to me. Talking about CS5mx I decide to give up of this project due to the complicated calibration procedure. Anyway, thanks for your help about this. Once more, please help about King Cobra, I realy like this MD. This is your fault you know.. I have PCb layout file in Sprint Layout of Royal Sabre got from Vladimir Demchenko but I think that's a King Cobra is much more interesting machine and that I will can gain it like I was gained TGSL to detect a 1 euro coin at 40cm. One more question about King Cobra's schematic.. at the schematic drawn by W.L. there is 5 (five) Electrolitics but at the picture of the PCB I see 7 electrolitics!?!? I think maybe there are more disagreement between schematic and original PCB layout. Please help. I'll pay you a beer when we see ... Indeed, if you need any help, anytime but I can help you in any matter I'll do it gladly.
          Thank you.
          King regards,
          Darko
          hello Darko,
          you can order PCBs right now from me. paypal accepted.
          All the best
          • #80
            Pcb order info
            Hi Kt315 can you send me paypal info so i can order one please i also have many pics of mint original king cobra board bot sides if you would like case pics too
            • #81
              copy vs. original
              • #82
                You will get small expirience in SMD soldering too. It will be useful for you if you are a beginner (small bonus). There are a places at bottom side for SMD resistors and capacitors, I added especially them as a filtering-blocking in power supply lines to ICs.
                P-CAD Component Locations
                RefDes Layer
                C43 Bottom
                C55 Bottom
                C56 Bottom
                C57 Bottom
                C58 Bottom
                C59 Bottom
                C60 Bottom
                R79 Bottom 18-24 Ohm
                R80 Bottom 18-24 Ohm
                R81 absent, do not set it
                A type of the capacitors is tantal 7343 or 7343H, value is 47 or 100 uF (the more the better), 10 or 16 V. A type of the resistors is 0805, 1206 or/and 1210.
                You can find the caps in any oldie apparatus - motherboards, videocards, HDD boards, etc. Ie that you are able to find around - and set these.
                • #83
                  good clickable illustrative pics. pay attention on THE +POLARITY sign.
                  http://www.eeweb.com/news/kemet-expa...tor-portfolio/
                  • #84
                    smd parts as like you see them on bottom side.
                    • #85
                      ups! misleading. my mistake, sorry. right voltage in this list.
                      RefDes Layer Voltage
                      C43 Bottom 16V
                      C55 Bottom 16V
                      C56 Bottom 16V
                      C57 Bottom 16V
                      C58 Bottom 16V
                      C59 Bottom 10V
                      C60 Bottom 25V
                      • #86
                        big size photo with the SMD's on bottom side.
                        http://i48.tinypic.com/xswg9.jpg
                        • #87
                          I see some apathy and indifference so thinking to put out clippings and files what I am keeping. may be it will be interesting for somebody.
                          The Manual
                          http://depositfiles.com/files/d9yzimbs0
                          • #88
                            The Manual
                            No Estamos Hasta Los Cojones.
                            Thank you for KC Manual. Do you have photos of populated and tested PCB?
                            • #89
                              WM6,
                              do you mean original or mine? I did full copy from original, but in the process I speedy found out the layout is not optimal as I did consider it. thought there is not a road aback anyway
                              trying to find 7660 in my garbage... then will follow...
                              • #90
                                The Manual
                                Can't load it
                                Grt Nakky
