Jeohunter - Visual Ground Scanner
  • Today Hunt
    Sir Funfinder, today i go to some old pales. in that pales one big underground area also present. on that underground i walk with jeohunter. battery is full, sensitivity is 80%, iron is ON, in this conditions my jeohunter shows cavity is 0%, Metal 5%, But iron is 85 to 95% in some places, in some places valuable is 90 to 98%. in both places metal % is only 5% to 8%. in graph also there is no rise points. it is cool and study going. what is this situation please give me idea.
    • Hi geo-i
      The most important thing in such a complicated situation is
      good information.
      The real Jeohunter hardware-profis are located in Istanbul, Turkey.
      Those have developed everything and know exactly the special
      spots to locate the problem, to trace the circuit and where to
      start. Those have the technical equipment for this task.
      This is a 3 layer PCB (printed circuit board) with modern
      devices on board - chips for the grafic and the computer
      operating system even very experienced electronic-cracks
      can't repair if a heavy or hidden damage was done.
      If you are done with the final tests (variable resistor with
      already removed chip) and again no result there's not
      much to do, especially without the needed money.
      You may order a working digital potentiometer chip
      and perhaps your soldering-skills already are good enough
      to attach it (is not a big problem, you could use little
      connection-wires leading to the chip, too).
      You cannot do any more damage, because the damage was
      done already directly after the faulty accupack connection.
      So you should try the final tests, you have nothing to lose.
      btw. one of your older screen-pictures has shown that
      perhaps the coil-detection circuit was damaged, too.
      geo-i, this is no simple analog radio to repair, this is digital.
      There are moving highspeed pulses from chip to chip
      also known as data-transfers and a multimeter is not enough
      to find out if everything works ok.
      Back to the needed information:
      have you mailed makro group and asked how much would
      it cost to buy an used replacement board inclusive 2 accupacks?
      If not, please ask so we have this information.
      How much money could you spent for the Jeohunter repair?
      What do you think would be the best solution?
      Good luck and thank you, I'm shure the minus 20-25
      degree celsius temperatures will be soon gone.
      btw. here you can see a real fantastic shortcut:
      nice fireworks with a car-battery:
      http://upload.wikimedia.org/wikipedi...uss_12V20A.jpg
      • Originally posted by syed ayub basha View Post
        Hello syed ayub basha
        please can you translate "pales" with a different word?
        The big question is:
        Do you have heavy mineralized ground at this location?
        Do you have analyzed the signal with the scan button?
        Your described values are standing for iron objects.
        But without proper ground balance or coil to ground
        distance at heavy mineralized ground the detector could
        have been moved outside of the "quiet reset zone range"
        and then there is no metal at all.
        Reduce sensitivity and use the scan anlayzing described in
        the pdf manual at page # 30 ( printed page # 28 )
        Getting an Analysis report by Analyzing the Target:
        so you can go shure if it really is a deep metal object.
        You can bury a metal object at some low mineralized area
        and find out at which sensitivity you get the best for you
        at the moment readable results. Or you can bury a metal
        object directly at this pales area, perhaps there are piles.
        Simply keep in mind:
        Press the reset button outside of the detection area and scan
        or detection results must be repeatable, clearly and identical.
        • why is it that the dealers in these miraculous machines can never show a buyer their extreme depth ,even though they stand to make a pile of cash on a sale ?
          you can draw your own conclusions
            Hi geo-i
            You may find someone who gives you some money for the broken Jeohunter so a new one costs you less or a different metal detector costs you nothing.
            New one?????
            Geo-i must be total crazy if he decided to buy a new one Jeohunter crap.
            You not only push a man to lost his hard earned money, top of everything what happen you do make fun of him. Shame of you.
            • @ target
              this is no miraculous machine and depth has to do with coils size and many other things you may know or not know.
              @ WM6
              WM6, you are such an unsympathical and disgusting insidious instigator that really no person should have contact with you!
              If you would be a lawyer or judge you would have been k*lled already for shure, you completly unfair and reality hating psycho.
              You're acting like a jealous pu** that wants to make all women bad around her because she can't stand those are better than her.
              WM6, we have already enough proofs that you must be completly crazy and I suggest next time take your pills before you post such dirty scum or consult your parents or your psycho-doc!
              Now you may laugh WM6 that someone gives you so much attention you're not deserving like a freaked out kid, but I really feel sad about you, because you must have a very hard real life if you act the same at home. WM6, just try to accept reality, even if you're a freak that is completly living in his own little electronical tinker world. Do yourself a favour!
              Concering geo-i:
              Shame on yourself, WM6, you cunning "Oh my heart feels so sorry about poor geo-i" lubricate comedian!
              Only a completly hateful and unworldy person would interpret my massive help for geo-i as an evil seduction and my suggestions what he could do now as "make fun out of him".
              And I don't have to defend myself against your filthy accusations WM6, because I give a sh*t what you are bla bla bla-ing!
              I warn you, WM6, never come close to real treasure-hunters with your pathological view of things, because those will lynch you!
              Don't ignore all my warnings I've written @ the modification-manuals concerning that someone really wants to try this mods and the detailed info about the accu-pack which works in the first time! But geo-i made a mistake later and mistakes can happen, terrible mistakes. It can happen faster than someone can think about. All the thousands of deaths each year out on the streets are proof enough.
              Perhaps it was fate, perhaps the time was not ready for this, perhaps the actual loss of the Jeohunter saved geo-i's life if he would have found a bomb at his bunker site. And making everything right in life is no warranty that nothing bad can happen.
              btw. I would hope that persons not just vanish after they used my help!
              Because I wanna know about their progress and how they're doing after some training with the Jeohunter!
              Perhaps geo-i now is waiting to get the needed replacement board or the info, and I wanna know what's happening.
              WM6, Your insane interpretations are proving what's going on in your confused mind... chaos, that will destruct you in the end or already very soon!
              Write some novels where you can live in your own extremly limited dreamworld instead of offending other persons with your disgusting provocations, cheap jokes, dirty lies and ridiculous accusations because otherwise this bad behaviour could end fatal for you.
              it's no computer-game...
                @ WM6
                I am sorry that you are no person.
                • sorry about off connection
                  :friends hello my best friend how are you sorry about the off connection, bro I do
                  not blame you I am gareful to many funfinder helps me a lot bro
                  I confess every mistake I did have done and sorry for everything
                  I sorry for trouble you for time being I guest I want to have rest
                  for a while ,I while continue contact you regarding our matter I
                  always do keep in touch let me completed my buget and I will refer
                  back to you bro,
                  dont worry about WM6 he did not have any connection between us
                  and I always 100% behind you funfinder always be a good friend for all
                  geo-i
                  • Originally posted by geo-i View Post
                    :friends
                    geo-i
                    I am 100% behind you both (without my wallet of course - only as observer this crazy scam story).
                    • @ WM6
                      You are an extremly poor character. Comparable with the witchfynder generals hundreds of years ago that wrongly accused innocent women and burned them to death!
                      You have nothing - you have no instruments for getting serious proofs! Just hearsay and small talk. You have no money at all so you can't test any of those detectors you are condemning.
                      You are such an evil living joke!
                      What do you wanna achieve? True depth information and true information about the capabilities of Metal Detectors?
                      Help, WM6 watches, he will find out if someone tells that his MD only would have 5cm more depth than in reality.
                      No, he'll find out nothing, he has no instruments at all!
                      He's like a scientist that likes to describe micro-organisms but he has no microscope!
                      WM6, I'm done with you until you will not seriously try to recovery your psychical health! Look for a therapy!
                      Don't talk with/write to me any more WM6 or you will regret this!
                      And if you furthermore try to insult the Jeohunter and its producers / owners, persons may stop you once and for all!
                      You are just spreading lies, hate and anger but I wanna enjoy my life without sick persons like you WM6 and the scum you bring along!
                      WM6:
                      *************, until your a normal thinking, social and fair person again!
                      • @ geo-i
                        Thank you my friend for your true and open words!
                        Simply ignore WM6, he has serious psychic problems.
                        We cannot help such persons, those need professional help.
                        As long as minimum one year has passed it's completly
                        useless to interact or communicate with this maniac!
                        He's locked and lost in his own poor world. He's some kind
                        of clown for this forum and I'm shure most persons here
                        already know that he has serious psychological problems
                        and what he writes has nothing to do with reality at all!
                        He will no longer disturb us!
                        geo-i, I really gave my best for helping you to repair your
                        Jeohunter and I'm happy you also have seen it the same way.
                        Sometimes repairing stuff is unbelievable complicated.
                        As example today and yesterday I tried to repair my little
                        snapshot-digicam - the lens didn't moved out anymore.
                        I had to disassemble the cam almost completly, I had to
                        find out how the mechanism works and finally I have
                        attached the front lens in a completly different way than
                        it was before. And - voila - I've been successful.
                        150 Euros saved!
                        btw. I took alot of Jeohunter pix with this cam because at
                        treasurehunting I had this digicam with me all the time.
                        But without extremly care and the needed tools it would
                        have been totally impossible to repair it.
                        btw.
                        2 days ago I bought 2 plastic wheels with 10cm diameter
                        so I can built something for the 1m Jeohunter coil
                        and if snow is gone I post some interesting tests.
                        geo-i, I hope you will get enough money and motivation
                        back soon again and hopefully a replacement board so
                        you finally can start treasurehunting with the Jeohunter.
                        And for the moment you need patience and always think:
                        You can never know for what a bad thing was good in the end.
                        At least now you have some very special replacement-parts
                        sometimes can became really precious.
                        Good luck, that everything will be fine for you in the end, geo-i!
                          @ WM6
                          WM6:
                          Thanks, dear Funfinder, to demonstrating here your excellent, refined and subtle personality. Comment no needed.
                          Can you explain a little more this your threats:
                          "Don't talk with/write to me any more WM6 or you will regret this! "
                          Last edited by Qiaozhi; 02-23-2012, 10:39 AM. Reason: Removed profanity from quote.
                          • Why this device always puts people in a fight??? here in Turkey also whenever Makro jeosonar(jeo hunter etc) or Nokta goldenking(or goldengate) metal detectors are inside in any topic, there people are getting crazy and swearing on each other... obviously these are stress devices, no matter for the user or the seller
                            • Hi funfinder
                              I have a question. Why do you manipulate your metal detector?
                              You will find it more depth?
                              Sensitivity of 100% can not get your balance.
                              If your metal is old you can detect this metal to the depth.
                              I,15 years ago, a ferrous metal, with dimensions 70 * 40 cm was buried at a depth of 3 meters.so i go to detect this target, by makro and my makro can detect this target at the 80%sensevity.
                                Hi, any new great discoveries at the secret remote project forum... ?
                                If you are getting a vertico just by watching you better
                                should not try this tecnique in real - you could end up
                                bumping into some trees, roots or other stuff.
                                Yeah, that's the way of "circle-scanning"!
                                Either you like it or not.
                                It may feel great to be the "gravity center" of your own world...
                                btw. if you only look straight at the coil and make a counterturn
                                when you found something usual you won't get very dizzy.
                                However it is the only real efficient way if you want to
                                look for treasures at sites where not every centimeter lies
                                a target.
                                Even 1 person holdable eliptical DD 1m coils could be
                                realizable which would be much better because you
                                could cover around 4 meters of diamater in one turn!
                                attached: the Jeohunter video (as another backup)
                                Hi fun finder
                                I can not download the zip file.
