1m coil ready for single person usage!
At the pix below you can see now the finished result.
Because the coil cable originally leads directly through the lower part of
the glass-fiber stem, I had to unsolder and resolder it at the connector.
For pushing or pulling the coil (both methods are possible) I'm using the
formerly original upper part of the usual coil-holder.
For the standard coil I built already a more lightweight alu-version
so I have now two different ones - and the best:
Both of them have an extra reset button included at the handle region!
To attach the wheel-device I'm using short ropes and polyester-belts.
On the pictures you see the "narrow" moving version which uses the
original stem-mounting. It will detect more precisely but it needs
longer distances for moving.
But the moving with the broad side variante also is possible:
Therefore a fitting board (wooden etc.) is needed inbetween coil
and wheel-device. To attach the stem only a little piece of
rope is needed which is wound around the middle of the coil and
leads through the stems plastic-screw hole.
The 1m coils cable is long enough to be used that way, too.
For pinpointing an additional small metal-detector would be good,
because an usual pinpointer may be not working good enough.
I guess that this new single usage version with wheels will be
even faster than the usual 2 person holding and walking around method.
Because of the wheels you even can run and if the ground is flat enough
it's very simple to move the coil all the time at a very good distance over the floor.
If two coil-holding persons would run over a field such task is much more complicated.
Well, the time (snow melts away) now is OK, so let's see when I will be able to report
about my first live-test. I'm very curious by myself because so far I never had tested
how good this coil works under real natural conditions. This coils reaches very good depths,
but I also wanna find out how deep it detects medium sized stuff and other things.
