Originally posted by Rov
Thanks for your positive interest. I think that there are not much problems in building the board. Some background in electronics is off course welcome… !
There are some different types transistors possible , but the used parts are very common so I think it is not hard to find them. If you use other parts take care for their pin configs!
For the coil you can find very much info on Geotech , the coil is not very critical and many options work !
The adjustments for the potentiometer can made by trial and error, no great risk in destroying parts. The adjustments for the volume and threshold potentiometers are very clear I think, the delay is somewhat stance… it has much influence on the sensitivity from the detector, searchs for the point where you have a good sensitivity for a golden ring, if adjustment is to far towards the transmit pulse, the detector will not work anymore, no harm is done, just turn back to the point where you had good sensitivity.
The adjustment from the offset potentiometer is the ‘most invisible’ …set the potentiometer in mid position at the first startup. If you have a scope than adjust the dc offset as normal. If you have not a scope look at the mail above I send to Ant. I think it is possible by listening to the sound if the adjustment from the offset potentiometer is at a good point. If anyone has works this out … please give your opinion ….
Of course it is very nice from Silverdog that he gives so a good service in offering very good quality boards for a very.. very.. low price’s! ( Think he cannot make a profit..) This makes it possible for large group friends to make this detector. It is not to hard now to make a good small Pi detector that works very good. But there is always a risk that there is a bad part ..or a mistake from the builder that makes it hard to get things going…
If there are problems …. ask on this forum..
Best regards.
Ap
