The kits are fine, unless you don´t have some electronics knolegments to apply
I had brougth lots of kints form silverdog and all of them works 100%. Sometimes you may found some minor details that can be solve without any troubles, so i sudgest you to read the schematic and for shure you will find where are your errors.
For the money that cost each kit, you have a shiper way to get a 100% functional detector. Keep trying , be patient and you will get succes.
Nelson
IDX-PRO+VDI
Many members have bought both the TGSL and IDX kits from Silverdog, and successfully constructed detectors that work. The problem is not with the kit or the information supplied. In fact, the TGSL design is one of the best documented VLF designs on Geotech. However, you must have a reasonable knowledge of electronics and some half decent test equipment. Although it is possible to build the TGSL without an oscilloscope (if you're very lucky, a careful constructor, and use a commercial coil) the chances are you will encounter many problems. Without the necessary knowledge and test equipment it is not an easy task.Originally posted by paku View PostToday i just want to say i have buy kit from silverdog is very dog and dog dog dog i have buy TGSL kit and IDX kit is just make me angry
when i make that farking TGSL its make many error so i stop it and try to make the IDX kit from silver dog dog dog and dog
when i finish make the farking IDX im still get many error on IDX kit from silver dog dog dog and dog
o when i check the schematic is not same on the circuit board is very like dog dog dog by theway thanks to send me the dog kit
you can make money with your cheat board
Yea I have heard about that one and the keys but there beyond rare finds and I love the idea of finding some thing that is really not ment to be there but with only the one been found I am more inclined to think it was placed/lost by someone in recent times.
Not so, a badly encrusted roman coin was found near port Melbourne pierI am in australia down the bottem end we get nothing like that :-(
Ok time to order a decent sized pic then.
I will give your decoupling caps ago .
And wow on those finds , , I am in australia down the bottem end we get nothing like that :-(
I found i could reduce the background chatter on my idx by adding decouplers to U3 - this enabled me to reduce the detect threshold and hence trip at lower level - which gave more air test distance.
I used 0.22uF caps on pin4 and 11 to gnd on pcb edge.
Found some bits of a Lancaster bomber today, and a roman brooch -- 2000 years of history -- 150yds apart.
S
Hello all
I am thinking about using a series of leds for my vdi as my minimal design will not allow for the standard vid lcd I may also incorporate a led digit display .
Using these I should get the same readout but be able arrange it in any fashion that suits.
Thorghts?
Ok thank you.
I get the slow (375k) and fast (220k) but what is the boost I see on the detectors with this mod?
Here:Originally posted by gtdavid View Postwhere could i get info on the mr bills s.a.t mod.
thanks
Reagards,
Fabián
If the coil housing has even a tiny amount of flexure this can be cause.
If the coax feed is loose on stem this can be cause.
If stem has flex this also can be cause.
S
my 2 tone board does not work and i have to turn my sensitivity to 0 to get it to detect anything..
otherwise i get constant beeping.
what could cause this would it be because i am using a fisher cz coil?
