IDX-PRO+VDI
  • Nandor
    Hello
    Look here "https://www.geotech1.com/forums/showthread.php?26060-Analog-Target-Indicator-for-VLF"
    The meter I used is taken form an old multimeter. The back panel was made with laser printer, it's 1mm aluminium panel taken from an old TV .
    I think that almost any kind of meter should be good for this project, the important thing is that it has to be a low power consuming needle ~ 1mA.
  • dgm
    Hi Good morning Mr. Nandor, I saw your last post, could you post or tell me where I can find information on the counter. Thanks for your intervention.
  • Nandor
    My IDX PRO with the analog meter
    Thanks Gurdal for sharing the meter documents!
  • gurdal
    Thanks Koala,
    Because of the pinpoint and discrimination feature
    I really like.I should look at other projects.
    Best regards
    Gurdal
  • Koala
    found some air tests for the original IDX with bills mods and original coils.
    Modified IDX Pro w/6?" diameter 5.3 BullsEye coil
    Internal Speaker w/audible Threshold
    Discrimination at minimum
    Toggle at 'Normal' / 'Black Sand'
    5? = 7?" / 8"
    1? = 7⅜" / 7?"
    25? = 8" / 8⅜"
    Killer B 'Wasp' headphones w/audible Threshold
    5? = 7?" / 8?"
    1? = 7?" / 8"
    25? = 8⅛" / 8?"
    Modified IDX Pro w/950 coil
    5? = 8?" / 9⅝"
    1? = 9" / 9⅝"
    25? = 10" / 10?"
    5? = 8?" / 9⅝"
    1? = 9?" / 9⅞"
    25? = 10⅞" / 10⅞"
    I found by adjusting the Rx capacitor you could increase the distance in air test by a fair bit. However it does not translate into real word improvement in the fields and made the machine unstable, with one exception dry powdery sand. For some reason air and ground closely match here with no negative chatter.
    I have seen YouTube videos with nearly 50 cm in air tests. This is possible. Just useless in the real world.
    Its been about 10 years since I have used the IDX
    from memory you could improve distance by changing the threshold slightly. If you turn it up too High you can't tell how deep targets are.
    My pinpoint / all metal mode was effected by which headphones I used. Again from memory I got an extra 1/2" using earbuds. But can't remember if that was before I changes the audio driver transistor.
    small thin silver coins on edge were almost undetectable on edge with a stock 8" concentric if you use too much discrimination
  • jawad
    Thanks a lot
  • Koala
    Originally posted by gurdal View Post
    hello good work;
    I made concentric heads for the idx pro detector in accordance with the values given. I achieved excellent depths in tabletop tests;
    but it does not exceed 20/25 cm in soil.
    I need your help on this.
    Best regards
    Gurdal
    sounds about right. Does depend on your ground
    I get 10 inches on a well worn UK pre decimal half penny.
    but that only with less discrimination than you would normally use
  • gurdal
    hello good work;
    Best regards
    Gurdal
  • gurdal
    Hi CDI
    Can you scan and add it with scanner.
    Let's copy it with sprint layout.
    i want to test
  • CDI
    hi masters,
    Is there a sprint layout file belonging to the circuit?
    Has anyone ever tested or has a video.
    Gurdal
    This is 2 tone version, i have one pcb for this machine, but not tested yet.
  • gurdal
    IDX PRO AUTO MAN TUNE AUDIO
    hi masters,
    Gurdal
  • Tibuck19
    Hi all;
    IDX Pro PCB Drawing Aid
    I like the design, you should also add an on/off switch pinout and a double pull double throw for head phones or internal speaker, perhaps even add a pinpointer toggle switch pinout. just a suggestion.
  • Koala
    if its a DD you made
    it matter which side of the null point you use
    I can't remember which side works best. But the phase changes and discrimination plus ground balance will be out. If you are right on the null point the coil became twitchy
    getting the shielding is also critical for a smooth running coil
    yes factory coils under preform but are ultra stable.
    I found however carefully I build a coil their always preform slightly different.
  • tomec123
    Thank you, that was a good and valuable tip. I now have 2 very good running coils ready. I also noticed that the original Whites coils have bad tolerances, I have 2 Blue Max coils, one oscillates on TX at 6.60 and the other at 6.62Khz. The coils that I made myself are exactly at 6.59Khz and have about 4-5cm better depth than the original ones. Only the DD27 coil can not run properly, despite the exact values, the ground balance cannot be maintained ... always missing sounds when panning ...
  • Koala
    Originally posted by tomec123 View Post
    I have finished my IDX-Pro with the original 950 spool for a while. Now I am experimenting with building another 250mm coil myself. The coil for the TX side is ready and with my single-channel oscilloscope I was able to set the frequency of 6590Hz exactly. Now I am faced with the problem of determining the RX frequency ... Where can I pick up this signal? Nothing useful is displayed directly at the RX output ... thanks a lot
    the RX not connected to anything or the RX circuitry will show the TX frequency
    you can connect the RX coil and capacitor to the TX to measure the frequency
    If you use the inductance and capacitors on page one of this thread everything is golden
