blisstool ltc64x v2i
  • Originally posted by target View Post
    theyre top guys they have no reason to talk them up .
    the truth will out.
    Yes, for sure, in between money on safe place and waiting on the truth.
    • LTC64X v3: Detection of a coin 24.25 mm @ 40 cm depth
      The only real problem ist the weak coils plastic and that
      there is no 50cm coil available for ultra depth search!
      And a reserve accu-pack or at least a battery meter.
      Seems they have already a 38cm DD coil - very good!
      http://www.youtube.com/watch?v=YQPKVG9nIv8
      • http://www.youtube.com/watch?v=sbe6F...ature=youtu.be
        • Thx target for this great video, really good job!
          Even if I have already the LTC64 (without X and Version 0 )
          I'm looking forward to get the v3 but with the 15 inch coil.
          It's still sensitive to small coins and stuff but depth for
          somewhat larger objects like cannonballs should be
          improved by 20% because of the coils size plus another
          at least 20% because of the improved circuit.
          But even my around 2 years old Blisstool already passed
          through the "cache @ 2 feet"-test last year - one pound of
          bottlecaps in fridge-bag at a diameter of ca. 20cm / 8 inch
          in high mineralized loamy soil.
          The LTC64 detected it with a very long and fading sound -
          if you ever should get such a signal it's a very deep target.
          There exists absolutly no doubt that the new Blisstool with
          38cm / 15 '' coil will pass the 1kg coins @ 2 ft test under
          usual conditions !!!
          target, please do me/us a favour if possible and compare
          the depth for small coins with the standard and 15'' coil.
          You can test some 0.5 to 1,5'' coins.
          PS. Does Blisstool provides already this good weather
          protection bag for the housing seen in the video?
          • Try to put in the same hole 1kg coins ,coated with varnish and no electrical connection between them!
            • http://www.findmall.com/read.php?18,1667371
              • More spam!!!! This dealer is on every forum trying to shift a few units.
                Seems the gullible aren't as gullible as they used to be
                • Originally posted by Pete B1 View Post
                  This is just an observation, as I've never actually seen one in the flesh (so to speak) ... but the "seller" (blisstool_uk) has yet to sell a single detector on eBay, despite re-listing a V2i and two V3s several times. His feedback is still zero. A used LTC 64X V3 with an extra 15" coil did manage to get sold in March from someone called "xpdeususers". Maybe we can draw our own conclusions.
                  There does seem to be a huge discrepancy between what we see in the videos and what certain others have to say about the performance.
                  Pete-B1 - Have you actually used a Blisstool, and if so what was your impression?
                  • Anyone got the circuit and more technical details for this one, be nice to see even just the layout.
                    • as for the bay the dealer uses it as a shop window and sells them direct to buyers by mail order or callers to the shop where they try them out before buying.
                      • Originally posted by Pompey View Post
                        No. Metaldetection works with induction currents so even lose "rusty" coins amplify the overall EM-field as we have tested already.
                        Besides: if metal-ions of long time ago buried corroded coins penetrate the surrounding soil this also improves the overall field effect.
                        Of course freshly buried old coins with bad surface contacts to each others are not as good detectable as new ones.
                        What really counts is the surface. A small thin layer of alu-foil 10x10cm is almost the same good detectable as a 10x10x10cm iron cube!
                        No matter if the alu-foil is cutted to tiny bits with no connection inbetween. You won't find a single coin-stack of 1kg where the top of this stack is at the 2ft mark, but if the 1 or 2 pound coin cache has at least 15cm diameter.
                        btw. a principal information:
                        Metal detectors have their electro-physical limits concerning signal noise ratio in combination with radiation / penetration power, coils size, ground conditions plus human detection skills!
                        Those are the multiplicators that counts, each single one of them!
                        The biggest problem with depths is the "blind field test" versus "already known buried target directly under the coils center" !!!!
                        Under real conditions depending on sweep speed and moving forward distance between those the real hidden target only is for about ca. 35% of the time at this "best position". And often the coil has more distance to the ground than at testfields with known buried targets. And with iron disc the total sensitivity is reduced, too.
                        The big advance to the Blisstool is its analog extreme critical threshold tuning thats why persons with experience and skill are able to distinct between static noise and very weak detection signals but not everyone is capable or trained for this. Because it takes alot of extra energy to listen very carefully to the "wood of signals".
                        However, if you consider the above mentioned arguments concerning "real search conditions with unknown targets" even the Blisstool won't find a 1'' coin at over 1 ft because there are simply too many disruptive factors.
                        Anyway, read all the test results here:
                        http://www.metalldetektortest.de/detektortests.html
                        and you have at least a very good "test situation" orientation.
                        Oh and before I forget:
                        I have bought now another ultra sensitive MD from Eastern-Europe that detects a 7cm diameter can at 1m but because of some extremly unfair and ignorant persons in this forum I will have to think twice if I even will give the slightest clue what kind of detector this is!
                        Just wanted to make some of these crazy guys a bit curious...
                        • c'mon out with it !ignore the lemon suckers with sour faces
                            c
                            Probably you mean ltc64 dealers, cause no one want to buy unstable detectors.
                            "Deutsch-Test" say nothing about detector stability in field so it is pointless and biased.
                              This is now "higher psychology" but sometimes it's the only way
                              if a person is able to ignore his own mind! In that case you have
                              no problems even if the own thoughts wanna drag you into topics
                              or memories that brings you down or could drive somebody crazy!
                              "Switching off conciousness", but without yoga, sleep, drugs etc.
                              However, target, I'm ignoring already some of those "every not
                              personal known MD must be a bad and bitter lemon - suckers"!
                              This isn't my newest metaldetector but a similar:
                              http://www.youtube.com/watch?v=NPbESqzlI-w
                                This is now "higher psychology" of those "every not
                                You are not bitter lemon sucker, you are self-sucker, and yes, this is something of "higher psychology".
