VACCUMM FORMING COIL HOUSING
I have been using 1/16" thick ABS from US plastics. It's fine for filled shells.. a little light for larger clam shells.
DonAttached Files
Not bad.. you are getting there. I went with a thicker form and eventually a two stage, vacuum cleaner for initial pull down and vacuum pump (air compressor intake) / vacuum tank and it made all the difference. I recently built an oven from an old 1500W heater and got the stinky plastic out of the wifes kitchen too.Originally posted by Wahyu View PostHello Don, how thick ABS sheet?
i made ABS sheet 1,3mm , not perfect at bottom
[ATTACH]38943[/ATTACH]
[ATTACH]38944[/ATTACH]
Don.
Yes, it's just a spare air tank. See attached.
Don.
Hi Chet.
I picked up a portable electric heater at a flea market for $5.00 and just repurposed the heating elements. I'm sure that I could come up with a link to a source for the elements. I also cut some corners on material. I lined a box with concrete backer board, which is not the right thing to do at all but I have not had any sort of problem yet. The walls of the oven get to around 250 degrees F but should be good for around 600. Ideally, a refractory material should be used. Anyway, my oven is 16" x 16" x 6" deep. It also has no thermostat so I need to manually monitor the temp which as not been a problem so far. I should be looking for a set of plans!!
Don..Attached Files
Was just watching your vid and you mentioned mfg's use forced air to remove the plastic from the shell, maybe just reverse your shop vac hose from intake to exhaust to force the new shell off. seems like it would work easier than beating the wood form out on the ground... just a thought, hec you probably have already tried that...
Originally posted by dfbowers View PostJust uploaded a new vacuum forming video that shows how to make a clam style coil housing.
https://youtu.be/6prgi5MrtQQ
Enjoy!
Don
