Originally posted by algan
Bipolar PI design
I am also not very aware of this matter - especially with these chips - peak.Originally posted by ivconic View PostIt is very difficult to find anything in the book that is not very interesting.
But I immediately decided on the Bipolar PI design as the first thing to focus on.
There are several reasons for that.
First, I like the idea of a "non-invasive" detection method because of the possibility of adapting this project for demining purposes.
Second, this approach is only the tip of the iceberg of possibilities for further development of PI detectors. That is my humble opinion, there are probably many who will disagree with me.
I have tried to participate in the AMX thread a long time ago but felt deprived of the vast knowledge that the other participants in the thread undoubtedly have.
Then I realized that I still have a lot to learn in order to be an equal interlocutor with others.
Luckily Carl's book is here, I have plenty of time to read and study. And now I'm slowly (after all, I'm quite old) starting to understand some things.
That's why I think Bipolar PI design is a good initial step and an introduction to some broader knowledge.
Carl offered very interesting solutions that "provoke" further thoughts.
There are two parts in particular that I really like. TX and audio. I wouldn't dwell on audio for now, because I think it is necessary to make it first and only then draw conclusions.
At this point I would focus on TX first.
Originally from the book Bipolar PI TX looks like this:
But I want the readers of this forum to look into your words.
A good friend mailed me two PICs from a neighboring state... a long time ago!
They never arrived.
It happens with our local mob called "Post and Customs".
So I am forced to think about alternative solutions.
Porting code from PIC to AVR is an interesting task.
These days I am preparing to try it.
But I'm out of shape!
Because I have an inflamed nerve in my shoulder that produces sharp pain and interferes with my focus.
I flipped through the book again and looked at the source code that Carl provided.
I had a problem at first because Carl is a huge fan of abbreviations that don't resemble anything!
And the worst thing is when he mixes up those abbreviations and uses one in the text and the other on the schematic!
Oooooahahahaha!
Carl... another suggestion for "Errata"...
Right now I'm an "idiot" and I don't understand anything.
Here is the graph and timing.
As a dumb programmer I need a literal translation of the train of pulses into the correct order.
Source code comments didn't help me much!
Carl is "The Duke of Obfuscation"!
His works do not need additional copyright protection!
And here is the first attempt at porting the code:
(I checked on an Atmega328P, it actually works!?? But you need to organize the timings better...)
Warning!
The code is under development, NEVER try it with mosfets if you are not a fan of white smoke!
Code:#include <Arduino.h> #define TXP_PIN 9 // Transmit Positive Pulse (PB1) #define TXN_PIN 10 // Transmit Negative Pulse (PB2) #define ADC_POT A1 // Potentiometer for delay adjustment #define TCLKP 2 // Demodulator control (PD2) #define GCLKP 3 // Demodulator control (PD3) #define TCLKN 4 // Demodulator control (PD4) #define GCLKN 5 // Demodulator control (PD5) #define BCLK 6 // Charge pump control (PD6) #define LED_PIN 13 // Debug LED (PB5) // Timing constants for 5kHz PPS #define TX_PERIOD 200 // 200µs period for 5kHz PPS #define TX_WIDTH 50 // 50µs TX pulse width #define MAIN_DELAY 15 // 15µs delay before sampling #define MAIN_WIDTH 10 // 10µs main sample width #define GND_DELAY 5 // 5µs ground delay #define GND_WIDTH 40 // 40µs ground width volatile unsigned long pulseDelay = MAIN_DELAY; // Default delay after main pulse void setup() { DDRB |= (1 << PB1) | (1 << PB2) | (1 << PB5); // Set TXP, TXN, and LED as outputs DDRD |= (1 << PD2) | (1 << PD3) | (1 << PD4) | (1 << PD5) | (1 << PD6); // Set control pins as outputs Serial.begin(115200); Serial.println("Bipolar PI (5kHz PPS)"); noInterrupts(); TCCR1A = 0; TCCR1B = (1 << WGM12) | (1 << CS10); // CTC mode, no prescaler OCR1A = 16000; // Match value for 1ms (assuming 16MHz clock) TIMSK1 |= (1 << OCIE1A); // Enable Timer1 interrupt interrupts(); } ISR(TIMER1_COMPA_vect) { PINB |= (1 << PB5); // Toggle LED for debug } void generatePulse() { PORTB |= (1 << PB1); // TXP HIGH PORTB &= ~(1 << PB2); // TXN LOW delayMicroseconds(TX_WIDTH); // TX pulse width PORTB &= ~(1 << PB1); // TXP LOW PORTB |= (1 << PB2); // TXN HIGH delayMicroseconds(TX_WIDTH); PORTB &= ~(1 << PB2); // TXN LOW delayMicroseconds(pulseDelay); // Delay before demodulator signals } void controlChargePump() { PORTD |= (1 << PD6); // BCLK HIGH delayMicroseconds(50); PORTD &= ~(1 << PD6); // BCLK LOW } void loop() { generatePulse(); controlDemodulator(); controlChargePump(); delayMicroseconds(TX_PERIOD - (2 * TX_WIDTH + pulseDelay + MAIN_WIDTH + GND_DELAY + GND_WIDTH)); // Adjust cycle timing for 5kHz PPS } void controlDemodulator() // 25uS delay is just for testing purposes, don't be confused by this... { PORTD |= (1 << PD2); // TCLKP HIGH delayMicroseconds(25); PORTD &= ~(1 << PD2); // TCLKP LOW delayMicroseconds(25); PORTD |= (1 << PD4); // TCLKN HIGH delayMicroseconds(25); PORTD &= ~(1 << PD4); // TCLKN LOW delayMicroseconds(25); PORTD |= (1 << PD3); // GCLKP HIGH delayMicroseconds(25); PORTD &= ~(1 << PD3); // GCLKP LOW delayMicroseconds(25); PORTD |= (1 << PD5); // GCLKN HIGH delayMicroseconds(25); PORTD &= ~(1 << PD5); // GCLKN LOW //delayMicroseconds(25); delayMicroseconds(MAIN_WIDTH); // Demodulator pulse width } /* * Reserved * void controlDemodulator() { PORTD |= (1 << PD2); // TCLKP HIGH PORTD &= ~(1 << PD4); // TCLKN LOW PORTD &= ~(1 << PD3); // GCLKP LOW PORTD |= (1 << PD5); // GCLKN HIGH delayMicroseconds(MAIN_WIDTH); // Demodulator pulse width PORTD &= ~(1 << PD2); // TCLKP LOW PORTD |= (1 << PD4); // TCLKN HIGH PORTD |= (1 << PD3); // GCLKP HIGH PORTD &= ~(1 << PD5); // GCLKN LOW } */ /* * void generatePulse() { PORTB |= (1 << PB1); // TXP HIGH PORTB &= ~(1 << PB2); // TXN LOW delayMicroseconds(TX_WIDTH); // TX pulse width PORTB &= ~(1 << PB1); // TXP LOW delayMicroseconds(3); // DEAD TIME (adjustable) PORTB |= (1 << PB2); // TXN HIGH delayMicroseconds(TX_WIDTH); PORTB &= ~(1 << PB2); // TXN LOW delayMicroseconds(3); // DEAD TIME before next cycle } MOSFET Switching Characteristics IRF9640 (P-Channel) Turn-On Delay (td(on)): ~25 ns Turn-Off Delay (td(off)): ~100 ns Total Switching Time: ~125 ns IRF740 (N-Channel) Turn-On Delay (td(on)): ~10 ns Turn-Off Delay (td(off)): ~80 ns Total Switching Time: ~90 ns -P-MOSFETs (IRF9640) turn off slower (~100 ns delay) -N-MOSFETs (IRF740) turn off slightly faster (~80 ns delay) ************* -1 µs dead time between TXP OFF and TXN ON -1 µs dead time between TXN OFF and next cycle -Prevents shoot-through & protects MOSFETs ************************************************** void generatePulse() { PORTB |= (1 << PB1); // TXP HIGH PORTB &= ~(1 << PB2); // TXN LOW delayMicroseconds(TX_WIDTH); // TX pulse width PORTB &= ~(1 << PB1); // TXP LOW delayMicroseconds(1); // DEAD TIME (~1 µs) PORTB |= (1 << PB2); // TXN HIGH delayMicroseconds(TX_WIDTH); PORTB &= ~(1 << PB2); // TXN LOW delayMicroseconds(1); // DEAD TIME (~1 µs) } ************************************************ */
Exactly.
I didn't even use pot at this stage.
So I reserved the IRQ and put in a trivial LED for now.
There is no inconsistency, but the abbreviations for the pulses do not match on the graph, in the text and in the schematic.
Although I understand English, sometimes it takes me time to decipher some abbreviations and understand them properly.
I made a mistake in math (I was never good at it) and instead of 5kHz I'm measuring 1/2.
Hmmm... we need Joop here!
Porting is not easy for me...
Hello ivconicOriginally posted by ivconic View PostExactly.
Which key will you use to control the samplers?
Algan no, it is for this currrent Bipolar PI, the topic is about.
Pechkata,
...potentiometer, but in this present code is not used yet.
Code is not finished, it is under development.
You can only test it with Atmga328P WITHOUT mosfets.
I thought it would be a good idea to make a code suggestion, so other members could contribute.
between TXP turning off and TXN turning on.
The MOSFETs (IRF9640 and IRF740) specification shows that the P-channel MOSFET turns off a little slower (~100ns), while the N-channel turns off faster (~80ns).
Suggestion: We can increase the dead time to 1-2µs to make sure there is no overlap.
TXP and TXN switching order
We need to make sure that first TXP (the P-channel MOSFET) turns off, wait for the dead time, then TXN (the N-channel MOSFET) turns on.
The same applies when switching from TXN back to TXP.
PORTB |= (1 << PB1); // TXP HIGH (P-channel MOSFET on)
PORTB &= ~(1 << PB2); // TXN LOW (N-channel MOSFET off)
PORTB &= ~(1 << PB1); // TXP LOW (turn off P-channel first)
delayMicroseconds(2); // DEAD TIME (~2 µs) - increased for safety
PORTB |= (1 << PB2); // TXN HIGH (turn on N-channel MOSFET)
PORTB &= ~(1 << PB2); // TXN LOW (turn off N-channel MOSFET)
delayMicroseconds(2); // DEAD TIME (~2 µs) before next cycle
If we're talking about the circuit in Fig 22-18 (post 169) then the NMOS switches are self-driven. TXP & TXN refer to the positive and negative TX pulses, not the PMOS and NMOS switches.Originally posted by algan View Postbetween TXP turning off and TXN turning on.
