Originally posted by Ferric Toes
On the TX coil current picture you can see the switching transients at TX ON and OFF. On the RX input, there are LP filters that reduce this noise. Since the input is differential, there is a common mode LP filter and a differential mode filter. These filters have a cutoff frequency above the smallest target TC.
The diodes do not clip. They are only there for protection against gross problems with induction balance. Therefore we see a "pure undistorted" full cycle wave form.
The coils are in a co-planar concentric configuration. As shown, not shielded, noise is not a problem in the extremely noisy lab, but when I get into high gain, the coil is sensitive to my hand. When using a solderless breadboard, any bad contact in the input increases the "hand sensitivity" considerably, so I think the sensitivity may be related to unbalance in the differential mode. I have not tried a stacked configuration yet.
I think that what you call a long tail, is caused by the TX energy being re-conducted to the battery or storage capacitors. At 10k PPS and 4A peak coil current, the power consumption is about 400mA.
This reverse current in the TX coil eliminates the need for a damping resistor, as it also eliminates the oscillations.
Another effect of the reverse current, is that the field it builds, kills the existing eddy currents in the target. After about 50us, all eddy currents , even for very long TC targets, are nulled. An interesting effect is that (at least in simulations) the amplitude does not seem to matter, only the TC.
In other words, it seems to be possible to measure the time it takes to bring the eddy currents to the zero point and thus get the TC of the target, instead of measuring the exponential slope of the decay, to define the TC of the target.
