FPGA based UNIPI system
    Looks like a nice chip ... the AD7760 is strange ... the Eval board all built up and tested is only a few dollars more than the one off chip price ??? Be interesting to see what you can make of the AK5578.
    I was tempted to move away from the FPGA to a CPU ... but will stick with the FPGA now as it can deal better with weird timing issues that seem to crop up with the ADCs. Besides the FPGA makes for a nice multichannel realtime builtin oscillscope and logic probe which is invaluable for debugging the DSP and ADC logic. I am ordering some FPGA boards from china to replace my obsolete boards but the VHDL code will be the same.
    If you are making a board for the AK5578 then I would also be interested as the 2.5 MSPS that the AS7760 offers is nice ... but prob not necessary.
    moodz.
    Progress on the AKM board. Not fully routed yet, but you get the idea.
    I've used the Raspberry Pi Pico 2 as the controller and this also provides pulses and timing for my TX board.
    The board is 100mm x 100mm and as you can see most of it is taken up by the 8 analogue input channels.
    Once I evaluate it and see whether there really is a 9dB improvement in the noise floor when using all 8 in parallel, I may use the 2 or 4 channel device which is a bit cheaper and will reduce my real estate accordingly. It's all a trade-off; More space and cost for better noise specs.
    Cheers,
    Olly
    • Originally posted by Olly View Post
      Cheers,
      Olly
      That looks very cool. Going back over the scheme I am using there is no need to use an FPGA or costly ADC. Although as you say there is a tradeoff.
      • In the mean time I have ported the all the code from spartan 3 to spartan 6 ( which was mostly just re-mapping ports ) Although I did convert everything to signed math from bit of a mish mash that was there before.
        I also added more traces to the onboard VGA "virtual oscilloscope" for signal inspection.
        Here is a short video showing the full depth discrimination in air of the new code.
        Basically there is a target amplitude ( ferrous non - ferrous ) that will be indicated by polarity of the target amplitude.
        I dont do VDI ... I only do GOLD ... NOT GOLD
        Auto ground balance is still working ... added a rotary control to fine tune the final result.
        The sensitivity is on par with a PI detector ... but is more noise resistant than a PI. ( and it can discriminate )
        So single frequency detectors with full discrimination depth and PI type sensitivity are possible .....
        ... and next I start on multifrequency. ( is it worth it ?? )
        https://www.youtube.com/watch?v=lmAqRtBEq34&t=23s
        • ... more coding and now the audio is hammered into shape.
          The non motion discrim works really well so the non motion mode is dumped.
          There are two audio modes ... Disc target and All target.
          Here is a video showing the audio in acition.
          https://www.youtube.com/watch?v=RlNB8OU3vss&t=8s
          • Looking good Paul, well done.
            cheers
            • Originally posted by Mdtoday View Post
              cheers
              Thanks Brian ... the previous code only worked on the R ( conductivity ) channel only ...so was finding all metallic targets. The new code uses the R and X signal but now is very good at separating ferrous non ferrous. However there is one thing that if the conductivity of the iron ( eg a big mass ) exceeds the ferric effect then depending on the orientation of the target the detector will give a non ferrous response. But long bolts, wire .. rusty stuff will show ferrous.
              I have done some ground tests on sandy wet / clay soils with lots of ferrous litter and the ground balance is better than I thought it would be. ( I thought the detector was not working because it was so quiet. ) The method definitely works and there is room for improvement because I scaled the transmit power down to save on battery. ( 30 volts peak to peak on the tx coil ... but can do 200 ).
              There is a very slight drift in the X R channel so I will be putting a push button to rezero every 30 seconds or so ... If I auto adjust then the detector mode changes from non-motion to motion. The ground balance is separate .... maybe a push button for convenience also.
              There is a slight negative R reaction to sea water but no problem with targets.
              Composite targets ( iron and non iron ) ( eg a coin and a screwdriver ) give a double ping response ... eg low tone / hi tone / low tone ... so you can still pick the coin.
              Depth tests will have to wait till I get down the bush over the next week.
