GPR - project
  • gwzd
    don't be sorry, most people here are very nice and helpful. Many are in one way or another involved in commercial companies as employees or even owners and sensitive information won't be posted here for obvious reasons.
    Even though, you will find tons of information here you won't find anywhere else and that's the great value of this forum.
    So, welcome to the forum!
    I don't post very often because sometimes I just don't find the time, but there are many others always willing to help.
    wish you the best
    RA
  • bajes2008
    sory...
    Originally posted by gwzd View Post
    Thanks! I'm right! I'm right!....
    well, you know, you share if you want to, that's the whole meaning of the word sharing. It's a voluntary action and if you cannot take a joke then you are in trouble .... dear.
    RA
    you know ? u r wright....maby im sinsetive too much...im so sory
  • gwzd
    Originally posted by bajes2008 View Post
    You are right dear. But that signs of genius nerves are crazy. If you do not have the intention to partesebate your design in the forum. So why if it comes from the begening. Is it not a subject of nerves?
    RA
  • bajes2008
    hi..wz
    I think you need a beer and some chill out music.
    cheers,
    RA
  • gwzd
    cheers,
    RA
  • bajes2008
    enough is enough seeker
    Dear seeker maybe you're a fan of Electronic Engineering, or perhaps be an engineer ... but most of all, you are good at drawing attention and attention. Maybe this is one of the hobbies as well .. but this does not give you the right to manipulate the members of this forum and ridicule them and laugh at them .. it a disgrace .. and I can say with confidence that all members of this forum are enthusiasts for gold traders, but not as claimed by .. and say you will not be published here .. if your design to what all the fuss if it does not? Better to be published here on your site and your friends and not .. and you know that not everyone is supposed to be knowledgeable in electronic engineering in order to build the device you .. or is it the question of individual muscles to the needy members?? If .. I advise you to stop this farce .. and enough is enough.
  • gwzd
    Probably because someone, whose name is Franklin, did probably invent this type of antenna array.
    http://www.centurion.com/home/pdf/wp_omni_wireless.pdf
    Really?! no kidding?
    See on page 1 figure a)
    This antenna is optimized for 2.4 GHz for an impedance of 200 Ohms. You need a balun to change its impedance into 50 Ohms (WLAN).
    I have a prototype of this antenna and it is working well (for WLAN). But probably not convenient for a GPR project.
    you've got no clue how a gpr works, do you?
    This was not my invention. So there is no need to alter your books.
    Oh! thanks for that! I was already starting to worry!
    RA
  • Aziz
    why is it called a Franklin Antenna? I propose from now on we call it an "Aziz antenna"! I'll have to correct that in my books!
    RA
    The page you are looking for cannot be found. Use this page to navigate to the part of the site you are looking for.
    If the reflector is reduced (removing the wings), it could give still a good directional antenna. But then, the antenna has to be recalculated (optimized).
    Something like this:
    These antennas are also called "Amos" in the web:
  • gwzd
    Multichannel gpr systems work in several different ways:
    1. can be multiplexed, so no tx/rx pairs work simultaneously
    2. can be one antenna transmitting and all the other receiving.
    3. can be firing in a sequence, that is alternating, but still no multiplexing like the SIR-20 from GSSI which is a true dual channel unit.
    4. can be with directive antennas like 3D Scan from Norway.
    5. probably many others more that I just don't know about
    RA
  • miki73
    One more question if im not borring.How that work in situacion with 4.transmither in corner of quad scaned place.This transmiters is sincronius with reciwer too or that method work on some other way?
  • miki73
    Thank you!Now i have clearly picture.
    Regards too all!
  • gwzd
    Here is one of my several developments: a high gain 21 dbi franklin antenna.
    model source: http://mitglied.lycos.de/pp4nec2/files/index.html
    RA
  • gwzd
    GPR usually works with two antennas, one transmitting and one receiving. The pulses are extremely short compared to the range of investigation. For instance, consider a 100ns (yes, that's right, nanoseconds) range with a 500MHz antenna. The pulse width is approximately 2ns or only 2% of the desired range. And, yes, it is the strongest one and therefore often damped at some extend. In transceivers which has the same antenna transmitting and receiving more advanced techniques are used, but that is out of the scope of this forum.
    I guess this helps.
    RA
  • miki73
    Are somebody know gpr working principe?
    Gpr firs transmite signal and then recive..like pi detector,
    or contnious transmit and recive,in that case how transmit signal not blind reciver?
    Regards!
  • epitopios
    GPR - project
    Seeker wrote Jun 2006
    ....The helical antena have many advantages to another types and rotating polarization give us 20dB attenuation between TX and RX signals in straight reception. ....
    I dont disagree but also have a look at:
