Wanted "ADMIRAL"
  • CEBRAIL
    Originally posted by Zotchin View Post
    Your goal is 35cm ok. For what?
    I build this one in the picture it is 2 tone by nikko i guess
    In air test i catch a coin 14mm between 15 and 17cm look picture . Is it good or bad?
    My language is arabic if you understand it will be good
    Maybe i will try to change some things
    Tx1.162 MH 428nf 7.137khz rx8.60mh. 48nf 7.833 kHz txrx696hz
  • Zotchin
    Originally posted by CEBRAIL View Post
    tx 1.162 mh 428 nf rx8.60 mh 48 nf.close to 800 hz l kept the rx frenzy high. ln 12 cm brick. successful.soil trials 22 cm. my goal is to reach 35 cm
  • CEBRAIL
  • Zotchin
    Tx 1.162 428 nf. Rx 8.60. 48 nf
    Thank you very much
  • CEBRAIL
    how to mesure 5 mv in rx and how to reach it
    i need some help
    actuly i wante to increase the detection destance
    thank you
  • Zotchin
    i need some help
    thank you
  • Zotchin
    Thank you very much again.
  • nikko10
    This is a multi-turn trimmer resistor (100-200 ohm) for setting the voltage of the transmitting coil, an undistorted sine wave of 16-18 volts is set
  • Zotchin
    How much is the variable resistance value beside the 470uf capacitor.
    Thank you
  • Zotchin
    Thanke you.
  • CEBRAIL
    32 DD tx 1 mh Rx 7.50 mh demiri silmiyor rx 080 mili volt tx 7.50 milivolt
  • nikko10
    turn the "discrimination" potentiometer until the ferrous metal is removed
  • Qiaozhi
    y. x olan yere ne takılacak ben ayrımı yakalayamıyorum tx 1.050 mh 330 n rx 7.50 mh 47 n
    metal ayrım yapmıyor bu konuda yardım edermisiniz
  • CEBRAIL
  • nikko10
    X and Y points, LCD indicator is connected
