Originally posted by Midas
For a traditional PI TX pulse, we can consider each pulse as an individual transient event.
For example:
The eddy currents generated by a linear pulse ramp penetrate about 2mm deep into a gold nugget, within about 250us.
When we switch off, the current inverses, we could say it comes out of the gold nugget. The rate of change of the magnetic field is now much higher that when it went in, therefore the eddy currents it generates, are of much higher amplitude.
Does this make sense?
I am sure we can find a few more angles to look at it. Let's see which one we decide to be the most correct one.
It also would be very interesting to build a real accurate LTSpice model for simulating PI detectors. The spice model I use above, gives results that are roughly similar to the results obtained with a real part circuit, but it could be improved a lot.
Is somebody willing to help me with building a more perfect PI LTSpice model?
Tinkerer
. So really it's the analogue ccts not the CPU that is the problem.
