DEEPER PI DETECTION DEPTH
    I think we need to stick with Carl's numbers, 100us TX. Otherwise we compare apples and potatoes.
    Unfortunately, Carl has not given the target TC's. The target TC is what makes the difference.
    On the sawtooth, when we look at the eddy currents increasing during TX ON, we see that the 15us target eddy currents increase until about 50us, or roughly 3TC, then they start decaying, in spite of the current ramp still raising nearly linear. Does this suggest that the target is "saturated"?
    The longer TC eddy currents are still rising at switch OFF.
    When we look at the flattop, we can see the same behavior, but the decay is enhanced as the delta I diminishes and goes flat.
    There is a current spike at switch ON, that distorts the behavior a little.
    Could it be that it makes a difference if the eddy currents are still raising at switch OFF, or that they are already decaying?
    Tinkerer
    Can you attach your latest simulation file if you updated? I'm not sure I'm looking at the exact same data. Does Qiaohzi file have all your latest changes in it? His is the easiest to use to compare for some questions.
    I think we have to keep in mind the di/dt of it all. The current in the target I think should be driven the di/dt of the current in the TX coil. The current in our MD RX coil will be driven by the di/dt of the current in the target. We have double differentiation here the way I see it.
    Basically yes, but... The reason the slow target current is still increasing in magnitude is that it is far from saturated and the TX slope is almost constant.
    However, the slope of the sawtooth is actually decreasing at a slow rate.
    The reason the fast target starts decreasing when it does is because it is tracking the slope of the TX current much faster (than the slow target) and, although it does not completely "saturate" (of course it takes infinite time to completely saturate) to the initial slope of the TX current, it actually grows higher than for the slope of the TX current later on (sorry for that head-scratcher). So it starts tracking down to be proportional to the reduced slope of the TX current.
    (Use photoshop and draw a line from the start to the end of the sawtooth ramp and you can see how it is decreasing in slope.)
    If the TX current was a perfect linear ramp, even the fast target should be still increasing and approaching a constant level, and naturally way ahead of the slow target.
    Pretty sure I got that right...
    My own personal intuition is that our RX coils will respond like a "secondary target", so they will be driven by the di/dt of the target current and respond according to their own dynamics (which is second-order, not first-order like normal targets).
    Looking at the graphs, I think it really is more a matter of how big a jump and how fast the target current changes on its wild ride, which wouldn't seem to depend much on the direction the its eddy currents are flowing, more on the level they are currently at if anything (although it doesn't seem to depend very strongly on that either).
    We really need to add the RX signal response to these simulations and look at that, not just the target signal.
    -SB
      Edit on the above.
      I just run it again, and it has now the same oscillation in both sims. The oscillation disappears when the Mosfet gate resistor is changed from 10R to 100R, or, in other words slowing down the switching a little bit.
      Looks like Miller effect. Fast voltage changes on the drain capactively couple through to the gate turning it back on. Definitelty a real life effect I was getting it on my POS MD. I implemented the same solution.
        US nickel and US silver dollar, whatever they are.
        Agree, below is a real oscope plot (using my nifty new Rigol) of my test circuit, upper trace is the coil current. Glitch disappears when 100 ohms is added to the gate, which slows down the slew rate.
        - Carl
          ..how big a jump
          =Supply current/voltage
          ..how fast
          =Supply frequency
          A target (coil) has an impedance, which is frequency dependent.
          PS: To see the induced voltage behaviour at the receiver coil, just replace the I(L3) by d(I(L3)). d() is the first derivation of the term in brackets.
          PPS:
          A high stimulation frequency will lead to a lower target eddy current (due to impedance). On the other hand, the RX coil would see more induced voltage due to higher eddy current change dI/dt.
          So, where is the free lunch?
            Actually, case 1 has a larger delta I (change in current) in the target. Since magnetic field follows current, could this not actually create a larger signal in an RX coil? Or at least virtually as much? In other words, no penalty for established current?
            -SB
            G'day Simon,
            Well my thoughts on this are that although case 1 has a higher current change in the target, the problem is once the turn off current has reached 0 and we are able to sample the target only has 250uA compared to the 650uA in the target that had the flat top(case 2) We are only able to measure the signal during the off time conventionally but if something can be worked out to sample during the flyback and reject ground response well then case 1 would win.
            Now what if we were able to make a current pulse that is square wave, rather than the current pulse that we end up with, with the resistor in series with the coil. We would have a fairly rapid rise at tx turn on and once the desired current is achieved(say 3A) we then hold it at that for(200uS) and then turn it off. This will give enough time for eddie currents in larger targets to settle before turn off. A switch-mode power supply would be ideal to drive this to minimize losses. Yes this will use more battery power, but who cares, li-ion batterys are cheap and light and if I'm finding more gold it will worry me not
            Cheers Mick
              The simulation model of the target cannot "saturate", unless you add a core model.
              • Something to think about.
                - Carl
                The same thing happens in the simulation. Increasing the gate resistor to 100 ohms almost removes the glitch.
                However ... just to throw a spanner in the works ... here's a simulation with the mosfets replaced by ideal switches. The glitch is still there.
                • Originally posted by Mechanic View Post
                  G'day Simon,
                  Cheers Mick
                  Mick,
                  what is better:
                  Wasting high power for a long pulse duration (saturated TX coil current) or
                  wasting low power for multiple short pulses (collecting the signal response over multiple short pulses)?
                  This question applies to all members of course.
                  Cheers,
                    Mick,
                    what is better:
                    Cheers,
                    G'day Aziz,
                    The method that finds big chunks of gold of course
                    For big gold I am leaning toward the longer slower pulse as it will take longer for the eddy currents to build and decay during the on time. The higher the current in the target after the coil current has reached 0 the better well thats my thoughts anyway.
                    Cheers Mick
                      The expression "saturate" is often used, it could be changed to another expression often used,"fully charged", which is just as wrong, to say the the eddy currents have reached a maximum level.
                      Tinkerer
                        - Carl
                        The oscillation is due to the parasitic capacitance of the coil. ie. inter wire capacitance, coil to shield capacitance and cable capacitance.
                        I used 200pf parallel capacitance to the 300uH inductance to simulate this.
                        If you change the simulation for 500pf parallel capacitance, the glitch increases. If you change it to 20pf it disappears.
                        Tinkerer
                          -SB
                          The linear ramp. Yes, the ramp is not linear and that is the most probable cause. I will make a different sim with a flatter ramp to see if this will show a difference.
                          The only thing changed on my sim, is the gate resistor to make the 2 sims equal.
                          Qiaozih's simulation is very different.
                          Tinkerer
                            G'day Aziz,
                            Cheers Mick
                            The difference in power consumption is very large. 2.4W compared with 17.3W.
                            Tinkerer
                              =Supply frequency
                              PPS:
                              Thanks Aziz,
                              this is a great help.
                              While we are at it, could you tell me how to make different inductance coupling:
                              I have: K1 L1 L2 L3 L4 L5 L6 0.0001, where all inductors have the same coupling. I want to add a Bucking coil, where the k factor is different to the RX coil from the TX coil.
                              I tried and crashed the LTSpice about 20 times. Could you please help me?
                              Tinkerer
                                Tinkerer
                                It seems you've found the cause of the glitches.
                                I modified the simulation (with the ideal switches) by removing the 200pF parallel cap across the coil(s). The glitches have vanished. However, they were still there (slightly) when reduced to 20pF.
