Home made coil shells/housing/casing ideas
    https://www.thulemann.de/Hobby-h-s-u...te-/kat-11.htm
    made from a flower pot, and one u-shaped Profile
    hole Price is under 10€
    That was pretty creative, I like it.
      Thats much the same as the BBsailor's idea. The main difference is that the paint can lid is usually bigger diameter, so it will be suitable for let's say coils in the 30cm range. Also the groove there is a bit deeper/wider.
        After somemechanicalwork,the lower part of mammut child chair become perfect fit for the spiral coil. You can in fact wind it directly on the housing. Pics below:
          KISS (Keep It Simple) Coil Housing
          Still a work-in-progress, this was made from 100mm sewer pipe (3mm wall thickness)
          A sheet of PVC was made by splitting a 300mm length of pipe down the side, softening it with a hot air paint stripper gun and flattening it between two sheets of MDF board.
          The 200mm diam circle was cut out using a jigsaw and the 'ears' with an oscillatory Renovator tool. The cutouts are each 35mm x 35mm.
          Once I tidy up the cable connections I will weatherproof and protect the coil with a coating of neutral cure silicone sealant
          The ears were then bent into shape with hot air and wooden blocks as formers - it pays to wear thick gloves when handling the hot plastic.
          I have also made a 260mm diameter one but it may be too flexible.
          P.S. the coil is bundle wound wire from cat5 shielded with copper tape (400uH 1.4R) - seems to work well on my Pickini.
            One more suitable fold-able chair, cant say the manufacturer, bought in Carefour. Cost a bit more - 8$. Also the hinges discovered on Russian MD forums. Look at the pipe clips. I found that type which uses not only screw, but a channel and trapezoidal plug(see the arrow). Very handy, but without zeggy(jigsaw) its hard to make the holes. Time consuming as well. The hinges(clips) will be glued additionally with epoxy, just for any case.
            Enjoy
              [ATTACH]44370[/ATTACH]
              [ATTACH]44371[/ATTACH]
              Great idea and cool! I have also been making pvc sheets out of pipes ... can't get any where I am and the L-profiles I can get are too skinny and soft.
              I heat them in the oven for good while. I am really enjoying this u-pvc re-forming stuff.
              As Goaty says - USE GLOVES - I use rough leather welders gloves. They are a bit bulky, but no heat problems at all.
              Hot plastic burns are sort of slow-lingering and you won't really notice until its really happened. Hope that describes it.
                Reading somewhere i get this idea
                https://www.ebay.com/itm/2Pcs-Nylon-...t/263755264535 and than find out the next two:
                ATTENTION -the deck hinges are coming at different angles. Make sure you have exactly 90 degrees one. Some of the Chinese claim they sell 90 degree but they will send you wrong one!!!
                  I think vacuum forming would be a good idea..
                    If you do this hobby long enough, it's worth making your own.
                      Looks gorgeous. However i'm not grown experience wise enough to start forming. May be when i get back home and set up own shack...
                        wow when i made my first pi coils before i got "proper" shells i used frizbee's the normal 7" ones and a 12" one i found in a "seaside" shop in cornwall, all these a great ideas.
                        its like Ian dury said "there aint arf been some clever bast?$ds" lol.
                          Yeah, the problem with the Frisbee is you cant find them any more in the stores. Seems the kids prefer PS, Xbox, I-pad and so crap instead of the fresh air and exercise.
                          ATTENTION - Beer(virtual;-) for the one who can give me a link to online store selling Frisbee. The only one i can source these days on Aliexpress and ebay are soft,rubber one.
                            Hi Tibuck19, Would you share the .stl of your coils? They look amazing!
                            Thanks in advance.
                              Thanks in advance.
                              Go to thingiverse.com and search for "metal detector coil".
                              None by Tibuck19, but there are a few examples there to choose from.
                                yeah you are right about frizzbee's not being around anymore, i have only seen them in 2 places lately, once in a huge pet store in the dog toy isle, and in a "seaside shop"(a certain type of shop in uk seaside towns) that sell buckets, spades, crab buckets and allsorts of cheap imported tat.
                                Trusted supplier of PE & sports equipment for schools. Quality brands, expert service & rewards to help teachers stretch budgets & elevate physical education.
                                try these mate.
                                aly.
