Originally posted by marin2
I have also provided a full description of the equations used and how it works in: Inside the METAL DETECTOR - Second Edition - Published 2015Originally posted by cvele View PostBravisimo Qiaozhi!
I use it for years and have no idea that it is yours work. It is simply the best!
regard
See Appendix A - Air-Cored Coil Calculator.
Is it key voltage of the pin 23 ?Originally posted by jladre View Post
I get a different voltage on pin 23 (4.3V)
Should I check the circuit?
Expect more Information!
Hi everyoneOriginally posted by jladre View Post8.5 inches, ordinary copper wire(silver plated stranded wire would surely add performance), 22awg, 360uH, 1.2R, double basket wave coil, damping 383R, sensitivity 20 (without annoying noise) freqyency 200, pulse width 130, delay auto, speed 7, integ w 26, ground 2,..im using different transistors, no 12v voltage regulator, no tantalum cap.. For another video sure i can if i have free time its the same result for sure..
About damping 383R,What is it,How measure it?
I'm a entry-level enthusiasts,so these messages are very important to me. A related post or guidance.
Thanks!
Yes, you'r perfectly correct.Originally posted by samii View PostDamping R is parallel to coil, original value is 390R 2W. There are 2 x 390R.Damping connected to ground of IRF and parallel to coil.
BTW,Does it need to match with coil?
I tested multiple coil,it's difficult to match.
It's not as easy as the designer said.
Hi marin2,
My apologize because I didn,t believe you about this numbers, now I get them by myself. Problem and solution are simply!
Your mega328p has arduino bootloader ! Just change H fuse from D1 to D9, erase chip, than go again L fuse- E7, H fuse D1, E fuse FC, and burn hex file.
That is all!
Regard
Yes karim1980, that is wright-only lf357 give proper numbers; but 37, 37, 45, gives ONLY LOADED ARDUINO BOOTLOADER! Yesterday i forgot to erase bootloader and guess what? Those numbers appears.Originally posted by karim1980 View PostHi marin2
Your problem is from ici . lm318 -ua741-Does not work with the device They give weak numbers Or large numbers
Look for the original one lf357
regard
