  • Originally posted by marin2 View Post
    How do you calculate coil?
    Coil Calculator
    • Bravisimo Qiaozhi!
      I use it for years and have no idea that it is yours work. It is simply the best!
      regard
      • Originally posted by cvele View Post
        Bravisimo Qiaozhi!
        regard
        I have also provided a full description of the equations used and how it works in: Inside the METAL DETECTOR - Second Edition - Published 2015
        See Appendix A - Air-Cored Coil Calculator.
        • I have a test,use Lf356 replaces Lf357
          Additional 10%
          • Hello, cvele and everybody
            As if by chance
            I press the down button
            While a piece of iron was under the coil
            The numbers are increased to A = 470 B = 600 C = 845
            I think my 357 is good
            And my coil is not good
            I used the calculator
            • I use the transistor 2n7000 instead of BS170
              Is what it is for this that I have a bad delay and the indicative numbers are always low A 30 B38 C70
                Originally Posted by 6666
                jladre
                would it be possible for you to take a reading with your multimeter for me please, if you cannot thats OK.
                I am interested in what dc voltage you have on pin 23 with no target, and coil away from all metal, thanks.
                I got 3.83 volts.
                Is it key voltage of the pin 23 ?
                I get a different voltage on pin 23 (4.3V)
                Should I check the circuit?
                Expect more Information!
                  8.5 inches, ordinary copper wire(silver plated stranded wire would surely add performance), 22awg, 360uH, 1.2R, double basket wave coil, damping 383R, sensitivity 20 (without annoying noise) freqyency 200, pulse width 130, delay auto, speed 7, integ w 26, ground 2,..im using different transistors, no 12v voltage regulator, no tantalum cap.. For another video sure i can if i have free time its the same result for sure..
                  Hi everyone
                  About damping 383R,What is it,How measure it?
                  I'm a entry-level enthusiasts,so these messages are very important to me. A related post or guidance.
                  Thanks!
                  • Damping R is parallel to coil, original value is 390R 2W. There are 2 x 390R.Damping connected to ground of IRF and parallel to coil.
                    • Originally posted by samii View Post
                      Yes, you'r perfectly correct.
                      BTW,Does it need to match with coil?
                      I tested multiple coil,it's difficult to match.
                      It's not as easy as the designer said.
                        thank you very much cvele
                        I have decreased to 24 turns
                        But it's always better 37 37 45
                        Detection coin of diameter 3 cm to 14 cm
                        Hi marin2,
                        My apologize because I didn,t believe you about this numbers, now I get them by myself. Problem and solution are simply!
                        Your mega328p has arduino bootloader ! Just change H fuse from D1 to D9, erase chip, than go again L fuse- E7, H fuse D1, E fuse FC, and burn hex file.
                        That is all!
                        Regard
                        • Now i have a problem i coil error i have to change the mosfets and always the problem
                          I will erase and redo the program
                          But with lm318 ca gives great numbers.
                          • Hi marin2
                            Your problem is from ici . lm318 -ua741-Does not work with the device They give weak numbers Or large numbers
                            Look for the original one lf357
                            • Originally posted by karim1980 View Post
                              Hi marin2
                              Yes karim1980, that is wright-only lf357 give proper numbers; but 37, 37, 45, gives ONLY LOADED ARDUINO BOOTLOADER! Yesterday i forgot to erase bootloader and guess what? Those numbers appears.
                              regard
