No target simulation. Change R11 to vary target time constant. L/R, 4uH/.1 ohm=40usecTC about the same as an aluminum soda can. Change L1(C par)to see coil resonance effect. Change R5 to damp coil with different C par. Playing with C par in spice, I'm guessing coil capacitance is a big reason coils act different. Adjusting R damping(R5) should solve the problem.
No I did n't compare amplifier... and i have mistake ,the problematic ic is the LME49990 ,not the LTE....
Do you have a scope? I would be interested in seeing amplifier out, similar to reply 1207 with the two different amplifiers(LF357 and LME49990). It might be easier to answer your question with the scope pictures.
Hi Green would you mind posting your spice file thanks,
would be handy .
I was thinking bias current but maybe not. Have you compared amplifier out with the LF357 and the LME49990. Including a LT spice simulation of what I think amplifier out might look like with no target and an aluminum soda can.
would be handy .
Also i tried 2 ICs LTE49990 at place of LF357 but did n't work at all. Any idea why??????
It makes sense, TDI coil is concentric coplanar right?
It's RX coil is smaller than at other two coils?
Also i guess it is most precise in behavior, among all three coils, right?
I did not check about discrimination or ferrous reject.
Maybe later...
I think that Commander and DIY coils needs a series resistor because they have smaller resistor than 1_Ohn that Hamid gives. Also if we see at waveforms we see that at these two coils there is something as small oscillation maybe from higher current.
Home made Basket 40cm coil (15.5")
A=277 B=578 C=720
Sens=15 delay=17 (11+6) Speed=10 GB=5
It detects a 1Euro coin at 28cm and a soda can at 67cm with continued sound.
Whites TDI 12" Dual Field
A=345 B=691 C=786
Sens=15 delay=19 (14+6) Speed=10 GB=5
It detects a 1Euro coin at 25cm and a soda can at 55cm with continued sound.
