  • Why don't you just post the circuits and procedures here? Why make it so long, you've never seen a circuit diagram, you've never seen a 3, you've never seen a 4, why not make a Felezjoopi, which is hundreds of times better than this toy
    • try to make tl12000 its stable in ground and deep search coil. i kow many people have it. i make this pikini v4 i tested it in ground it works . nice projet.
      • send the kit to Brazil
        • Nothing wrong with the Pickini4, great little detector! It found me a gold ring with diamonds at just over 12 inches! Hope you're fit and well Bernard! Regards, Marty.
          • Hi to all please mat machine pickini have a problème. (Sensitivity decreases too much). Ennyone hère help me
            • IAM using this pcb but sensitivity decreases why. https://www11.0zz0.com/2023/10/01/13/864822868.jpg
              • Originally posted by Reedick View Post
                Hi to all please may machine pickini have a problème. (Sensitivity decreases too much). Ennyone hère help me
                • Iam testing all component. Irf740. No error. Bs170. No error bc549. No error. What is the problem
                  • What do you mean with "sensitivity decreases" ?
                    Was the sensitivity OK and has it dropped ?
                    Has the detector worked OK ? or is this the first time you test it ?
                    Can you adjust the sensitivity potmeter between 0-5V ?
                    Can you show a picture of your actual board ( front and back ) ? The picture you show is the one from my website.
                    • Hi F117 no it worked ok but sensivity coil decreased into . Detected nothing
                      • Iwell chow you my pcb
                        • Can you also check your coil : measure it with an ohm meter ?
                          Are you getting the startup sound and after that the idle sound ? Or the coil error sound ?
                          • This is the correct link to the coil error sound:
                            http://www.willaert.world/MD/pickini...technical.html
                            • Hi friend ihave detect sound but after that sensivity decreased. . This may image. Pcb
                              • Friend can you give me detail for coil. 30cm diameter ohm and mh.
                                30cm=????ohm
                                20cm=???? Ohm
