Delta Pulse
    did you connect T9 Base to C27(+)?
    yes i do
    • Originally posted by freedan3d View Post
      Hi samifathi
      Your pcb is delta pulse discriminator lcd circuit and i have its all data
      I attach a rar file for you and other users
      enjoy it
      freedan3d
      hi freedan3d
      please the lcd file work correctly?
      best regards
      thnak you
      • Originally posted by pigeon View Post
        hi freedan3d
        best regards
        thnak you
        PI really do not think the detectors are renowned for their skills for the selection. The depth sensitivity is good.
        I do not think DP - LCD selects any metal. The original HEX file can not run it. Replaces the mechanical indicator (status bar). Works for me, but I do not expect her selection of metal.
        • Originally posted by Oorlam View Post
          You have done this and won 5cm? what you didt to acchieve this.?
          Originally, I made ​​an earlier DP. This is only auto-tune mode worked. Solved with a switch to manual mode.
          • Apparently, the discriminator module "discriminator rar" published more ago, is a demo that can be executed 200 times, as can be seen in the Turkish forum.
            The bars give a rough idea of ​​metal detected.
            Jose
            • Originally posted by Jose View Post
              Jose
              http://www.teknolojiekibi.com/index1.html
              Me too it appears on the LCD. (Without welcome words)
              It seems to me that this is not the same as the Turkish solution. I think it's no discriminator.
                yes i do
                check R44 and T9.
                • Originally posted by szucs_g View Post
                  HI
                  I NOT INTERESTED IN HEX I WAN TO NOW IF THE PCB AND COMPONENTS ARE CORRECTE
                  THANK YOU
                  BEST REGARDS
                  • Lcd
                    Can LCD be added to any delta pulse .I have a delta pulse and would like to add lcd
                      HI
                      THANK YOU
                      BEST REGARDS
                      Hi pigeon
                      yes this pcb and componnents are correct
                      it work very well
                      Its hex limited in on/off only
                      i solved this counter in pim-1 whit hex manipilation
                      it is not very important
                      ill try to make another delta pulse pcb and i can start again
                      best regards
                      freedan 3d
                        Hi pigeon
                        it work very well
                        best regards
                        freedan 3d
                        HI FREEDAN3D
                        THANK YOU VERY MUCH
                        GOOD LUCK
                        BESR REDARDS
                        • Originally posted by growdude View Post
                          Yes growdude it possible
                          which model yo use ?
                          you can find that points p1 p2 p3 p9 and p4 p5
                          connect its to lcd
                          good luck
                          Freedan3d
                            Hi pigeon
                            it work very well
                            best regards
                            freedan 3d
                            Hello Freedan3d
                            The card "discriminator rar". Correct?
                            thanks
                            Jose
                            • YES!
                              • i build delta pulse and i have problem
                                hi
                                first problem that the green and red led are light when connect 12 v
                                what the problem and need help to explain the function of damping resistor the value i use is 680 ohm
                                my coil is 31 turn with 0.4 mm and 19 diameter ask can i make shielded with aluminium foil and plastic case
                                i wait to help my and thanks
