Delta Pulse
  • mohandes
    Originally posted by Jose View Post
    Delta Pulse, Automatic Mode, coil connected away from all metal.
    Oscilloscope vertical sensitivity 10 mV per frame.
    Signal in "D9 pin 11".
    Signal in "D9 pin 2" .
    Signal in "D10 pin 2".
    Tensions in D7:
    Pin 2, 58 mV
    Pin 1, 5-10 mV negative.
    Pin 7, 100-400 mV positive.
    In my opinion, the integrator does not work or missing some or Tr5; Tr4 pulse, can be a key 4066.
    luck
    Jose[ATTACH]27481[/ATTACH][ATTACH]27482[/ATTACH][ATTACH]27483[/ATTACH]
    thanks
    i think manual mode better, and why all use auto mode ??
  • kt315
    Originally posted by g.s View Post
    I too have this problem with THE diodes.
    As a solution I use alongside two other diodes with good results..
    [ATTACH]27499[/ATTACH]
    there must NOT be the problem with the diodes. something wrong you have. thinking SOURCE pin of IRF740 you connected to (-E) point instead of it must connect to
    (-12V)= (-BATTERY).
  • porkluvr
    Originally posted by aaksts86 View Post
    tnx .... i fixed problem
    dead 1N4148
    Changed 1N4148 .. but after 30min burned down again :/
    maybe can be replaced with a better diode?
    Which one of the 1N4148 was it that burns? I assume that it was in the timer sub-circuit, but that still leaves two to consider.
  • g.s
Name:	delta diodes.JPG
  • aaksts86
    i have problem whit vd12 and vd13
    Generally these diodes are burned during rehearsals, when we make a short circuit.
    Disconnect the coil and measure the total consumption, the value should be 40 to 50 mA if all is well.
    If burned during power up, the cause could be very high value capacitors C7 and C8.
    Normal for C7 and C8 is 1000 and 10 mF.
    Can utizar other diodes, but it is preferable to find the cause.
    Jose
  • kt315
    added some copper pour and cutout at SENS pot pads. check.
  • Jose
    Originally posted by mohandes View Post
    okyellow is D9-11 and blue is D7-2
    [ATTACH]27480[/ATTACH][ATTACH]27479[/ATTACH]
    please measure by multimeter D10 out put pins and D7-2,3,1,6,7 and put it here (when coil connected do this please )
    Edit : i have 10volts on 555-3 and it is dc voltage ( is line wave not square wave or..wave )
    Tensions in D7:
    Pin 2, 58 mV
    luck
    JoseClick image for larger version
ID:	338607Click image for larger version
ID:	338608Click image for larger version
  • mohandes
    mohandes, send me a photo taken with the oscilloscope, the waveform at point "A" of the scheme, to compare with my DP. (ver.6 dp.JPG)
ID:	338606Click image for larger version
  • Jose
    dead 1N4148
    Jose
  • aaksts86
    dead 1N4148
    In the distance, we can only suggest possible solutions.
    If we have no pulse TR2, obviously comprises the step and its associated circuitry 556, do not work.
    This step will not work if lefalta feeding, which is the first thing to check, it often happens that for some reason opens one of the diodes D8 and D9, lacking the tension "-E".
    Check the voltage on pin 7 and 14 of the 556 "-E" and nearby components.
    Jose
  • Jose
    thanks jose
    but i need more help
  • g.s
    the my own Turns out gold deposit xa xa xa.......
ID:	338602Click image for larger version
  • mohandes
    Mohandes,
    To reduce the delay, is 1 nF C4, R7, 10 K. C6 can be reduced and the potentiometer "SENS" for better control of the second sample.
    Tensions in D5 pin 1 and 7 alrrededor fluctuate from 0 Volts.
    Same for D7 on pin 1 and 7.
    When metal is close to the coil, the voltage at pin 1 of D7, increases towards negative. The voltage at pin 7 of D7, increases towards positive, more than 4 volts if the object is large.
    In turn, the voltage at pin 7 of D8 (555) increases to over 3 volts negative.
    thanks jose
  • kt315
    kt315 YOU try the pcb YOUR .. works...and which are the results YOU..
    3 metres depth 15cm x15cm gold plate, eah? or 5??...
  • g.s
