how about steel wool ? been using that idea for 40 years if you are talking about the copper to solder
Delta Pulse
Originally posted by porkluvr View PostSome things are just plain wrong. Using gasoline to clean a PCB is one of them.
Ethyl Alcohol is best. And then if you have any left over, you can drink it mixed with your favorite beverage... enjoy it along with your favorite tobacco substitute.
Don't try that with gasoline.thanks guruOriginally posted by kt315 View Postto clean by gasoline last time and to fire. burn it out. with a residue. i can not see calmly a trash (
but i ask you and i try yet this part ver.6 dp.JPG ,so i think my problem here,but yet not found.i have a new board like turkey again tomorrow .
In the distance, we can only suggest possible solutions.Originally posted by aaksts86 View PostI replace ne556 ... and not working
test all soldering connection ... all ok ...
If we have no pulse TR2, obviously comprises the step and its associated circuitry 556, do not work.
This step will not work if lefalta feeding, which is the first thing to check, it often happens that for some reason opens one of the diodes D8 and D9, lacking the tension "-E".
Check the voltage on pin 7 and 14 of the 556 "-E" and nearby components.
Jose
thanks joseOriginally posted by Jose View PostMohandes,
To reduce the delay, is 1 nF C4, R7, 10 K. C6 can be reduced and the potentiometer "SENS" for better control of the second sample.
Tensions in D5 pin 1 and 7 alrrededor fluctuate from 0 Volts.
Same for D7 on pin 1 and 7.
When metal is close to the coil, the voltage at pin 1 of D7, increases towards negative. The voltage at pin 7 of D7, increases towards positive, more than 4 volts if the object is large.
In turn, the voltage at pin 7 of D8 (555) increases to over 3 volts negative.
but i need more help
tnx .... i fixed problem
dead 1N4148
Changed 1N4148 .. but after 30min burned down again :/
maybe can be replaced with a better diode?
Originally posted by Jose View PostIn the distance, we can only suggest possible solutions.
Jose
Generally these diodes are burned during rehearsals, when we make a short circuit.Originally posted by aaksts86 View Posttnx .... i fixed problem
dead 1N4148
Disconnect the coil and measure the total consumption, the value should be 40 to 50 mA if all is well.
If burned during power up, the cause could be very high value capacitors C7 and C8.
Normal for C7 and C8 is 1000 and 10 mF.
Can utizar other diodes, but it is preferable to find the cause.
Jose
okyellow is D9-11 and blue is D7-2Originally posted by Jose View Postmohandes, send me a photo taken with the oscilloscope, the waveform at point "A" of the scheme, to compare with my DP. (ver.6 dp.JPG)
please measure by multimeter D10 out put pins and D7-2,3,1,6,7 and put it here (when coil connected do this please )
Edit : i have 10volts on 555-3 and it is dc voltage ( is line wave not square wave or..wave )
Delta Pulse, Automatic Mode, coil connected away from all metal.Originally posted by mohandes View Postokyellow is D9-11 and blue is D7-2
[ATTACH]27480[/ATTACH][ATTACH]27479[/ATTACH]
Oscilloscope vertical sensitivity 10 mV per frame.
Signal in "D9 pin 11".
Signal in "D9 pin 2" .
Signal in "D10 pin 2".
Tensions in D7:
Pin 2, 58 mV
Pin 1, 5-10 mV negative.
Pin 7, 100-400 mV positive.
In my opinion, the integrator does not work or missing some or Tr5; Tr4 pulse, can be a key 4066.
luck
Jose
