Delta Pulse
  • Jose
    Hello Great Alex
    if i place a metal near coils the signal increase rapidly then the signals fade out and the device become retune itself ( i still have the peice of metal near the coil and the signal fade out) , it's like auto tracking mode !!
    first of all is it normal or my DP has a problem , any body has a video of DP when a metal object remain in a fix distance to DP coil ?
    and this auto tracking make the detector response very weak on deep targets cause it's speed is very high . i built a switch between T7 and R29 for this problem but i need changing it speed not to remove auto tracking at all.
    the description the previous paragraph is normal in the operation of the Pulse Delta, and corresponds the "automatic mode."
    You can try the "manual mode", then the Delta Pulse behavior is similar to other MD PI.
    José
  • betobrambi
    my friend Great Alexis
    These two diodes ( 4148 ) emit sound when I put multimeter to him... ¿must I change them?
    The other ones do not emit sound in multimeter.
    The 4001 does not emit sound... ¿That's right?
    If a piece emits sound, ¿ it Broken?
    thanks Alexis for your help me
    best regards
    Heriberto
  • betobrambi
    thanks Great Alex
    I am desirable knowing oneself and thanks to help oneself.
    do You say that he must blink constantly? The bawdy Led only becomes fastened like a focus of house. ¿What may I have made wrong? ¿Or that the piece does not work ?
    In addition, in the sound, he does not have it... ¿must I place a potentiometer for volume?
    or¿What must I do to invest resistance 1k?
    Great Alex. thanks for help me
    do I owe check with meter the pins out of every transistor?
    I do check all and inform you the aftermath
    I do not know if I will be able to, because I am not an expert .
    I will change transistors for new
    ¿is This possible?
    Friendly thanks
    Thanks again for your help.
    I come from Mexico
    Heriberto
    Te envio un fuerte abrazo
  • Great_Alex
    thanx jose and what about reverse audio response
    Betobrambi it seems you should test every thing from beginning
    first check the 1n4001 D7
    then you should check to have signal in some Test points
    you can use of a speaker for testing that u have pulse or not ; when one leg conneted to -12v battery use another leg of speaker to check the pulse signal !! strange way but works.
    check these places for pulse signal :
    check all diodes by a multimeter
    check the voltage pin 1 ic 6 and Batt +12v it should be 5.3 volt
    and check these place for pulse if you don't have pulse there there is a problem
    Pin 5 of 556 Ic1
    pin 9 of 556 ic1
    pin2 of lf357 ic4
    pin6 of lf357 ic4
    pin 6 & 10 of 4538 ic 2
    pin 6 & 10 of 4538 ic 3
    pin 1 & 7 of tl062 ic 5
    pin 1 & 7 of tl062 ic 7
    test these maybe you find where's problem
  • betobrambi
    gracias José
    Podemos hablar en español?
    GUsto conocerte y gracias por ayudarme.
    Dices que debe parpadear constantemente? El Led verde sólo queda prendido como un foco de casa. ¿Qué pude haber hecho mal? ¿O que pieza no funciona?
    Por otro lado, en el sonido, no lo hay... ¿debo colocar un potenciometro para volumen?
    o ¿qué debo hacer José para colocar la resistencia 1k?
    Gracias de nuevo por tu ayuda.
    Soy de Mexico
    Heriberto
  • Jose
    Hello Betobrambi
    Green LED should light all the time.
    Sound, controlled from Pin 3 of the 555 to 1K pot (volume control) and connection to the speaker.
    Regards, Jose
  • betobrambi
    my friends, info for your's
    my friendly, I want to inform that I solved to the problem of the lights leds…
    but now, the green LED (remains caught and it does not go out…
    green LED must be caught all along?
    I changed tl 062 and lm 555… in 2 occasions.
    not yet there is sound… I changed could help?
    thanks to read
    best regards
    Heriberto
  • betobrambi
    amigos
    the greatest photo, of nF red is my work…
    There is not no sound, illuminate leds either…
    Which is the error?
    I am not expert, but I am learning with you. It is my second Delta Pulse that I construct friendly Thanks for the aid
    Heriberto
  • betobrambi
    Kt315, friends and experts help me, please
    Knowing its knowledge in the Sniffer Xr-71… I at the outset bought to a Stilian Bulgarian the Sniffer with fuse (002383019-big.jpg) and
    it worked correctly, I had an error in coil connection and threshold became unstable… It sends beeep long if I place potentiometer
    after 5. It only works stable in number 3 of the potentiometer and reset does not work.
    But the detection of a softdrink can Coke to 35 cms.
    before the coil error in search, marked coke 90cms.
    It could help to solve the problem?
    Another thing, I constructed the Delta Pulse that attached…
    I have reviewed everything and seems to work correctly, nevertheless, it does not exist light in no of the centers leds
    nor is sound.
    It could help?
    Thanks for its aid.
    Him desire the best thing always.
    From Mexico for you, a strong hug.
    Best regards
    Heriberto
  • Jose
    Hi Great Alex
    The operation of the delta pulse is normal, as you describe.
    You can try changing the value of C21 to vary the response time, I think it is better not to touch.
    I try to manual mode, for continuous tone about the detected object.
    Regards Jose
  • Great_Alex
    Hi KT315 & all Delta Pulsers
    I think response time of Delta pulse is normal and no need to change
    I built 2 delta pulse with single sided pcb , both of them works the same
    maybe my DPs not works good they work like motion detectors ?!!
    best regards
  • kt315
    Originally posted by Great_Alex View Post
    Hi
    I have 2 question about DP :
    1. How can change the speed of Auto tracking
  • Great_Alex
    Hi
    2. I want to have reverse signal on vco it means when a metal approach to coil the sound decrease ! and when take it away the sound increase
  • Jose
    Hello
    Try to help. How many laps has its coil, diameter, damping resistance value?
    Jose
  • alkon_1
    HI ALL
    Dear Brothers,
    Did not answer me one question please, I do not know what to do
    The circuit works vice versa when you bring the metal does not come out and vote when you keep him out a simple sound, distance 5 cm
    Is there any better than this chipset has been tested and successful
    Please advise
    The required depth 3 TO 4 M
    [email protected]
    THANKS FOR ALL
