Bulgarian 'PULSE STAR' (... close to Legendary one)
  • dear georgi.g.zhelev
    is this osilograme for pin 3 ic 555 ok?
    • PS-G
      mesyna, until now all is well. Oscilloscope: "HORIZONTAL", including a 50mks
      Предложете по-добър превод
      C.L!
      • Предложете по-добър превод
        now all are OK - ?
        • PS-G
          now all are OK - ?
          Hi KT315! Hi everyone! Sorry for bad English, use GOOGLE translator. But here is the Tech Forum, a forum not an English filologi. OK? G.L!
          • hi georgi,
            please explain.
            how does it discriminate gold ,copper,silver and iron
            I know ,iron and gold has same delay time.
            likely 270 usec.
            jyst curve is different
            please explain more
            • PS-G
              Mesyna, sorry, mistake. Not the pulse width is 150 mks, corrected it to 150 mks.
              • hi dear georgi.g.zhelev
                150mks What is the difference 150mks They both are a form?
                Please recommend me a reliable pcb??
                I think my problem is that the pcb??
                With respect
                mesyna
                • PS-G
                  mesyna, sorry, but the problem is not PCB.Problem is lower your training in Electrical, Radio and Electronics, and lack of experience in the manufacture of metal detectors. You need someone who can help you. Manufacture of metal detectors is not an easy job!</SPAN>
                  G.L!
                  • PS-G
                    MESYNA, SEE !!
                    • tank you dear georgi.g.zhelev
                      now this osilogram for pin 3 (555) is ok?
                      • ps-g
                        mesyna, all ok! ne5534 pin 6 + 0,2 v (trimer).
                        • PULS STAR-G
                          Originally posted by okantex View Post
                          hi georgi,
                          please explain.
                          likely 270 usec.
                          please explain more
                          Hi, okantex, hi all! Discriminator how it works, I can not explain, no one can how.GURU know? Still works!! Before I did a little test:
                          GOLD (Au) COPPER (Cu); LEAD (Pb); SILVER (Ag); BRONZE ... ALL IS '"NOT FERRO "100%. IRON (Fe), aluminum (Al) "FERRO" 100%. Were granted me, That's true!
                          G.L!
                          • Originally posted by georgi.g.zhelev View Post
                            I pin 6 (5534) took measures. Voltage of 0.5 volts and with trimer time does not change at all. Once I replace the 5534 but was still constant voltage
                            Why's friend?
                            Please help me
                            With respect
                            mesyna
                            • ps-g
                              [цитирам = mesy64; 108759] Уважаеми georgi.g.zhelev
                              Аз ПИН-6 (5534) е взела мерки. Напрежение на 0,5 волта и с тример време не се променя изобщо. След като замени на 5534, но все още е постоянно напрежение
                              Защо приятелят?
                              Моля да ми помогне
                              По отношение
                              mesyna [/ цитат]
                              check scheme, trimer NE5534 pin 1 and pin8, middle edge trimmer R21 (27k) to +8 v
                                i chek all parts .
                                all is corect and according schematic.
                                trimer is conect pin 1 and pin 8 and r21 to +8
